Cylinder wall
Old Feb 17, 2007 | 05:01 PM
BakoLuke's Avatar
BakoLuke
Default Cylinder wall
is it possible to fix a crack in the cylinder wall?
Old Feb 17, 2007 | 05:33 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Cylinder wall
Yes, and here is how you do it. The best method is Flame Spray welding.
http://www.aa1car.com/library/ar497c.htm
Old Feb 17, 2007 | 05:44 PM
valley firearms's Avatar
valley firearms
That is a very interesting article. But, if you have a common 289 or 302 why not replace the block? I can understand if it were a Mexican or Boss block. Just my .02 cents.
Old Feb 17, 2007 | 06:53 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: valley firearms
Yeah, Valley is right. It would probably cost you more to repair than to replace an ordinary block.
Old Feb 17, 2007 | 10:54 PM
my77stang's Avatar
my77stang
you can just get that cylinder sleeved. you'll be needing to deck the block (which all of you should be doing anyways and alot of people dont) and get it bored obviously
Old Feb 17, 2007 | 11:34 PM
mustanglover66's Avatar
mustanglover66
I smell a rebuild! time for more power. I would get another block. Or go with a crate motor.
Old Feb 17, 2007 | 11:40 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
ORIGINAL: my77stang
+1 a got a sleeve on my cleve it was 100$ installed
Old Feb 17, 2007 | 11:53 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: rmodel65
ORIGINAL: my77stang
And in the back of your mind you will always know that cylinder is the weak one in your engine.
Old Feb 17, 2007 | 11:55 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
ORIGINAL: Soaring
ORIGINAL: rmodel65
ORIGINAL: my77stang
actually a sleeved cylinder is stronger
Old Feb 18, 2007 | 12:01 AM
my77stang's Avatar
my77stang
yup stronger they be. i wouldnt like it if i had to sleeve two holes next to each other, but other than that if they are done properly you mayt not even see that there is a sleeve installed.
we put 8 sleeves in a boss 302 block, i wanted to cry when they were doing it. soooooooo much machine work done to that motor just to have it grenade. i was heartbroken
