Which way does this mount?
Old Feb 18, 2007 | 01:46 AM
Toddman0025's Avatar
Toddman0025
Default Which way does this mount?
Trying to install this oil cooler sandwich plate - which side sits against the motor and which side does the oil filter attach to? Also, is there supposed to be a gasket where the lip is?
Old Feb 18, 2007 | 01:49 AM
whislndixie's Avatar
whislndixie
Default RE: Which way does this mount?
I believe that the side in the 1st pic goes against the engine with an oring seal similar to the one on your oil filter. Where is the threaded post that goes thru the center for the oil filter to screw on to? Just an observation.
Old Feb 18, 2007 | 01:56 AM
Toddman0025
Here is the threaded center piece, looks like it can go in either way...
Old Feb 18, 2007 | 01:57 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
+1 on the oring side toward the motr do u have the threaded piece for the adapter?
Old Feb 18, 2007 | 01:59 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the female side goes toward the motr the male side is for the oil filter
Old Feb 18, 2007 | 02:01 AM
Toddman0025
ok great - so just pull the o-ring off the next oil filter and shove it in the groove? and the new oil filter will not need an o-ring against the plate?
thanks for the help
Old Feb 18, 2007 | 02:05 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
you will still need a oring on the new filter you can get orings to fit the adapter just take it in and go thru the selection etc i wouldnt use an old one after its been used but u could get away with it more than likely or just buy a cheap filter and pirate it
Old Feb 18, 2007 | 02:06 AM
whislndixie
Just use an oring off of an oil filter to seal the adapter to the engine. The put a new oil filter WITH an oring onto the adapter. When you put the oring on the adapter it should look just like the oil filter where it seals up to the engine. You will need an oring on the oil filter to seal it to the adapter. You will probably have to buy two oil filters to get this accomplished or if you are trying to go cheap you could use the oring off of an old filter, but I wouldn't! You're only talking about five or six bucks.
Old Feb 18, 2007 | 06:17 AM
andrewmp6's Avatar
andrewmp6
rmodel wouldnt some of that blue or black gasket in a tube stuff work too
Old Feb 18, 2007 | 09:47 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
no it woule leak and start rather quickly id go to napa/ or car carquest and ask to see there orings they usually keep stull like that in the back
