Battery keeps dying
Old Feb 19, 2007 | 08:48 PM
  #21
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Battery keeps dying
ORIGINAL: ZZmustang
I bet
Right now you can go pop your hood and grab both battery terminats at the same time and not a thing will happen, except on your car , you would probably get dirty. And then start it up and grab both terminals and Nothing. Unless your standing in water.
Anyone want to take that bet?????????
And
Sor, Batteries are sealed, Unless you have one with caps on it, Then, You need a new battery.
ZZ......batteries are not "Sealed." It is imperative to have the gasses escape whenever pressure mounts. Therefore the "caps." Either each cell is capped individually or several are capped together, but they are still not "sealed." Here is a pic of my Interstate battery I bought last year. See the caps? Please do not unhook the positive cable when the engine is running. That is not good advice, and certainly not something that a mechanic would do.
[IMG]local://upfiles/10034/1A551B0CDD154B468B317450919406E5.jpg[/IMG]
Old Feb 19, 2007 | 08:50 PM
  #22
ZZmustang's Avatar
ZZmustang
Banned
A $600. system is always the way to go. I grew up with NO money and had to figure stuff out on my own.
Old Feb 19, 2007 | 09:07 PM
  #23
ZZmustang's Avatar
ZZmustang
Banned
[align=left]
Old batteries have removable caps as individuals or as a group. Sealed batteries are not really new but newer. They work upside down.
Go to any of the battery manufactures and put sealed car batteries in their search. I have one for my car. its yellow and has no caps. [/align][align=left][/align]
[IMG]local://upfiles/58274/71D26FE617344233B96388B907A0CE64.jpg[/IMG]
[IMG]local://upfiles/58274/A6FEDC7913CF495BA7918AA4DEFC408C.jpg[/IMG]
Old Feb 19, 2007 | 09:15 PM
  #24
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, you are right ZZ. I can't afford those.
Old Feb 19, 2007 | 10:25 PM
  #25
gothand's Avatar
gothand
Who is running a sealed battery in their early Mustang? I have always had them in my Jeep (both the Odyssey by Hawker pictured and the Optima Red and Blue tops) because I don't want acid spilling all over when I get it on its side. Also, they seem to hold up better under the jarring offroad and I run a winch which draws 450 amps. On an early Mustang, I don't know.
Anyway, I thought the guy already replaced his battery so that brings things back to a short in the car, no?
[edit] Just re-read the guy's original post and this has happened several times with his old battery and new batteries ... after a few trips around the block! Who gives a flying flip how to test if the alternator is charging if he has such a large draw coming from somewhere on the vehicle? FWIW, and I have to preface this by saying that it happened in a Range Rover (Lucas, Prince of Darkness), but the positive lead came off my brother-in-law's Rover offroad and it took out his charging system. That probably doesn't relate to this because that thing was such a POS, but why chance it?
Old Feb 19, 2007 | 11:55 PM
  #26
mikethebike's Avatar
mikethebike
ORIGINAL: fastbackford351
It isn't the voltage that kills you, it is the amperage!!!! A couple of amps and you will assume room temperature in a hurry.
Well, since the amperage is determined by the voltage/resistance....12 volts won't do a thing to you.....but the arc at disconnect could ignite the hydrogen gas being given-off by the battery.
Old Feb 21, 2007 | 05:26 PM
  #27
onuliakattack's Avatar
onuliakattack
I started up the car and checked the voltage at the battery and it said 8.5 which i know is about half of what it should be, so either the alternator is a dud or its wiring?
Old Feb 22, 2007 | 03:47 PM
  #28
kalli's Avatar
kalli
ORIGINAL: 65mojoe
ORIGINAL: ZZmustang
Wont fry a diode wont kill anybody, will work just fine. The alt puts out the same with or without the battery hooked up. Or it would fry a diode when the battery was full charged and can't take anymore. Unlike some people hear, the charging system has no brain, It just does what it is made to do.
pulling the negative side does the same exact thing, but without the risk of shocking the **** out ofyou.
works just fine. done a million times.
the only risk here is that if you remove the positive side first, your metal tool might hit ground (bare metal) at the same time (accidentally).
You'll have your tool red glowing instantly and you can severly burn your hand as well as fry your battery.
The same counts if the car is not running.
So ALWAYS start with negative side first (I haven't heard of someone accidentally hitting the plus side with the tool at the same time so far)
as to disconnecting the battery while car is running. with such a car no problem.
With a modern car you run the risk of voltage peaks ruining your injection computer or any other. The battery usually takes the peaks
it's a very valid test to check on the alternator on old cars. you don't know how high the charging amps are, but you know the generator is at least kinda charging.
You might as well stress it with putting on the full lights and radio or whatever.
Another method is to just hook up a voltage meter to a battery. All cables connected. voltage higher than when car is not running->generator ok.
This is not a 100% valid test. but works 99% of all times.
The only valid test is to disconnect minus of battery. hook ampmeter between minuscable and batteryminus and see how much amps are flowing into the battery.
kalli
BOB ROME
Jul 26, 2023 01:54 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
svfetter
Oct 5, 2015 11:39 AM
guitarman376
Sep 30, 2015 05:54 PM
logan409
Sep 26, 2015 07:43 PM
