installing new shocks
Old Feb 22, 2007 | 05:55 PM
jman67's Avatar
jman67
Default installing new shocks
I am planing on getting new shocks probobly kyb's. I am planing on doing the work myself. I wanted to know if the shock can come out through the top mount and would i need a spring compresser for this. Or does the entire spring have to come out. thanks
Old Feb 22, 2007 | 06:41 PM
paddy187's Avatar
paddy187
Default RE: installing new shocks
Jman it is an easy job even i did it!!! yeah the shocks can be just unbolted without needing spring compressors and pass through the top. As for the rear they were a problem for me bloody bolt was stripped so had to saw through the bottom shock bolt with a hacksaw pain in the ****
Old Feb 22, 2007 | 06:45 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, these are not coil overs, so you don't need a spring compressor. It will help if you can get a 2nd set of hands. Even a kid. The shock will turn, so you either need someone to hold it while to take it loose, or do as I did and put a pipe wrench around it and have the handle rest against the inner fender.
Old Feb 22, 2007 | 06:48 PM
ZZmustang's Avatar
ZZmustang
Banned
Two bolts at the top, two bolts at the bottom . Jack the caruseingthe A-frame so to keep pressure on the spring, Im assuming your talking about the front. Out threw the top.
[IMG]local://upfiles/58274/04AB76367FCC4DC182F8A10A02FEEADA.jpg[/IMG]
Old Feb 22, 2007 | 07:22 PM
restomod66's Avatar
restomod66
I just replace all four corners with KYB gas adjusts and it wasn't a hard job by all means. I did it myself and thought that it would be harder than it appeared to be. The KYB's are sweet and give a nice ride!!!!
Old Feb 22, 2007 | 08:07 PM
earlymustang's Avatar
earlymustang
I have a "like new" set of KYB's for front that I would sell to you very reasonably if interested.PM me if interested. I found an original pair restored so I will not need these. They worked very well. Probably put less than 50 miles on them.
ORIGINAL: jman67
Old Feb 22, 2007 | 08:19 PM
restomod66's Avatar
restomod66
I hear that bilstein's shocks are the way to go?? What do you think??
Soaring's Avatar
Soaring
I ♥ Acer
Hey Matt.....long time no see.....Where ya' been?
Old Feb 23, 2007 | 05:18 AM
paddy187's Avatar
paddy187
koni FTW good enough for shelby good enough for me, plus alot of the opentrack racers like them. There are some new ones that are easy to adjust in situ made by spax but I don't know if they are any good and pricy. Plus Doetsch Shocks seem to be like koni but half the price
Old Feb 23, 2007 | 09:59 AM
jspagna1's Avatar
jspagna1
Very easy to do. You can handle it. Problems you run into are very small. I had a tough time with one of the shock tower caps,nothing that a little heat did'nt cure. While your at it depending if the car is show & go you can replace with chrome shock tower caps. Nice touch.
