450hp 351w
Old Feb 26, 2007 | 04:05 PM
borsports's Avatar
borsports
Default 450hp 351w
what does it take to get 400hp out of a n/a 351w with out going out insane in the prices the cheaper the better but i dont want it to be a piece of crap because i took the cheap way any suggestion as to what i can do?
Old Feb 26, 2007 | 05:20 PM
white69mach1's Avatar
white69mach1
Default RE: 450hp 351w
stroker and a nice set of heads
Old Feb 26, 2007 | 06:12 PM
JBradley500's Avatar
JBradley500
edelbrock top end kit probably would be quite reliable and make 400hp.
Old Feb 26, 2007 | 06:30 PM
69MustangCoupe393cid's Avatar
im making a solid 425 with my 393, its got 10:1 compression, a 750cfm 4bbl, short tube headers, a performer rpm intake, with roush 500 heads, and a 2.5" true duel exhaust. Its also making 450ft lbs. The long block cost me 3k then add in the manifold, carb and whole exhaust. Ill say for 4-5k you can get a nice little engine. I got the long blcok through autozone, they get them through recon.
Old Feb 26, 2007 | 07:21 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
ok but now do it with all stock components
Old Feb 26, 2007 | 07:36 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
jst get some afr(air flow research)185 heads a good cam headers and a decent carb/intake and ull be over 400hp
Old Feb 26, 2007 | 07:48 PM
Soaring's Avatar
Soaring
I ♥ Acer
The biggest gain of all these components are the aftermarket heads and cam. Most guys run around with a 4V carb and dual mufflers and wonder why they aren't beating the ricers.
Old Feb 26, 2007 | 08:40 PM
BlackLX's Avatar
BlackLX
408 stroker, Canfield heads and a custom cam from Camshaft Innovations
Old Feb 26, 2007 | 09:04 PM
ORIGINAL: Brandontyler65
he didnt state that he was only using all stock components, just usig a 351, 4k for a 425hp engine isnt bad lol
Old Feb 26, 2007 | 09:25 PM
mustanglover66's Avatar
mustanglover66
I would go with a 418 stroker, but I would stay far away from anything made by recon assembly line engines. We custom build each of our motors and every one is broke in and run on the dyno. Each engine is shipped with the build sheets, dyno sheet and video. how does 480hp and 510 ftlb of torque sound.
http://tandlengines.com/ford_windsor...nchor-41-56037
