Electronic Ignition
Old Mar 2, 2007 | 03:31 AM
mySAVIOReigns's Avatar
mySAVIOReigns
Default Electronic Ignition
Right now I've got the points in my 6 cyl. and to be honest, I know nothing about it[8D] I'd like to move over to an electronic ignition system, but I don't really know what I'm looking for. Anyone have any good links/suggestions to something I could easily switch over to? Thanks
Old Mar 2, 2007 | 03:39 AM
az1966's Avatar
az1966
Default RE: Electronic Ignition
got the pertronix II and flame thrower,,,installed and works as advertized,,just be sure to get 12 volts to it,,,took about 30 minutes to install and check timing
Old May 6, 2007 | 12:18 PM
kuhlou's Avatar
kuhlou
any idea which part no from pertronix is needed for the electronic module for the 200 ci inline six? Thanks.
Old May 6, 2007 | 01:03 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
here you go http://www.mustangsunlimited.com/ite...atKey=EMUSTANG
Old May 6, 2007 | 05:48 PM
mat11089's Avatar
mat11089
I used the crane cams Fireball and i love it.It has a built in rev limiter also if thats of any importance and its like 10 bucks cheaper i think.
Old May 6, 2007 | 06:53 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
ds2 cause you can get parts anywhere
Old May 6, 2007 | 07:01 PM
Soaring's Avatar
Soaring
I ♥ Acer
Wow! Over a hundred bucks now. I got mine less than a year ago for 65 bux. Is it because that one is for a 6 banger?
Old May 6, 2007 | 09:28 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
idk maybe buts its also a petronix 2? is your petronix a 2 glen?
Old May 6, 2007 | 09:40 PM
1bandc69's Avatar
1bandc69
does your car have a thermactor, this will affect which pertronix ignitor you will need. Both the standard ignitor and ignitor II are a great choice. You can save a little money with the standard. Heres a kit at mustangs plus that includes a coil.
http://www.mustangsplus.com/Merchant...uct_Code=08624
Old May 6, 2007 | 10:09 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: rmodel65
No Stephen, mine is the first generation. Not sure why they introduced the II, since my I works just fine. I understand there are a few more amps coming from the II, but how much do we need with stock set-ups?
