where to get build sheet?
Old Mar 2, 2007 | 03:36 AM
az1966's Avatar
az1966
Default where to get build sheet?
I broke down my vin/data plate and the info matches the car,,,but it doesnt say what options or type of interior other than black vinyl,,so I don't know if it's deluxe or pony that sort of info like that,,,66 coupe 6 popper 3 spd ,,,thanks for help/info
Old Mar 2, 2007 | 03:48 AM
4reboy's Avatar
4reboy
Default RE: where to get build sheet?
Marti Auto Works does full vin reports.
https://secure.alevelhigher.com/mart...vinreports.cfm
that'll be what you need.
Old Mar 2, 2007 | 07:20 AM
bodyputtyless's Avatar
bodyputtyless
If your car has not been restored previously, you may try reaching under the front seat and feel up into the frame webbing to see if an original copy of your build sheet is still there. I found copies under my drivers seat, and under the rear seat in my 70 Mach 1. I have also heard of them being found under the carpet. If you don't have any luck, then Marti works is the solution.
Old Mar 2, 2007 | 09:43 PM
az1966's Avatar
az1966
thanks for the info but MArti starts at year 1967 and I gotta a 66
Old Mar 2, 2007 | 09:56 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: az1966
That's true, and you are SOL with Marti on your 66. So, who is going to win the Super bowl next year? I like the Cowboys. Seriously, you can't get any information about your 66 that is documented. Just drive it and and enjoy the experience and not worry about originality because there is no way to prove anything about the originally of any of the parts on your 66 Mustang. Forget it.
Old Mar 3, 2007 | 04:35 AM
4reboy's Avatar
4reboy
In other words what soaring means, is that ford trashed the documentation for models 65-66 then got smart and kept the documents after that. So then sadly marti won't work for your year because simply no information exists! sucks doesn't it
svfetter
Oct 5, 2015 11:39 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
the5
Sep 19, 2015 06:13 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
