Welding Questions?
Old Mar 4, 2007 | 06:16 PM
ACADIST's Avatar
ACADIST
Default Welding Questions?
Spent some time working on the first welds since high school............Make no mistake, they look like it too! Anyway after grinding down some excess I have four spots , all on the hump and firewall that burned through. In these areas is the original sheet metal thinner? What is the best way to patch this? None of them are very large, about 1/4 to 1/2 inch. I was thinking of taking some left over metal I trimmed from the floorpan and making small patches......all you real welders out there.........suggestions?
Old Mar 4, 2007 | 07:58 PM
67 evil eleanor's Avatar
67 evil eleanor
Default RE: Welding Questions?
What kind of welder. Mig or stick? If its a mig, turn down your heat a little and take your time and fill them with weld.Then grind them down being careful not to overheat the area. The metal should be the same thickness. Hope its not a rust issue.
Old Mar 4, 2007 | 11:36 PM
ACADIST's Avatar
ACADIST
It's all a rust issue....hahah. No, Thanks, I'll try it. I am using a cheap MIG
Dokilar
15
Oct 16, 2015 08:13 PM
jrrhd73must
Oct 2, 2015 09:17 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
