Exhaust calmps.
Old Mar 5, 2007 | 03:38 PM
sxs191's Avatar
sxs191
Default Exhaust calmps.
My car is smoking on both sides where the exhast manifolds connect to the intermedaite pipes. I am assuming (hoping) it's just the clamps of whatever connects the two. Can anyone tell me what I need to replace these piece's so I can look up the items to but new ones? Thanks, Scott
Old Mar 5, 2007 | 03:43 PM
NorCalTroy's Avatar
NorCalTroy
Default RE: Exhaust calmps.
There are gaskets that fit in the flange between the manifold and the pipes, they are pretty easy to replace as long as your bolts aren't rusted in place.
Old Mar 5, 2007 | 03:51 PM
sxs191's Avatar
sxs191
They are. So this is probably going to be a fun project. I need to get replacement bolts too. UGH!
Old Mar 5, 2007 | 04:01 PM
NorCalTroy's Avatar
NorCalTroy
PB Blaster to the rescue...
http://www.pbblaster.com/store/morei...m?Product_ID=1
Good Luck!
Old Mar 5, 2007 | 04:05 PM
sxs191's Avatar
sxs191
Thanks. Ihave stock in this stuff... Guess I'll start spraying...allot.
Old Mar 5, 2007 | 04:23 PM
Mustang Dad's Avatar
Mustang Dad
PB Blaster....greatest thing since sex. Use it liberally a couple of times the day before you try and break anything loose and it will come right off.
Old Mar 5, 2007 | 04:37 PM
OhioMachIRunner69's Avatar
OhioMachIRunner69
PB blaster, heat, and an impact gun...go to town.
Old Mar 5, 2007 | 04:49 PM
scott_m_mil's Avatar
scott_m_mil
Trust me you DONT DONT DONT DONT DONT want to break and exhaust bolt. I had the "pleasure" of working on a car for a friend of mine this weekend. Whatever *&(*&$#(*&%$#(*& worked on it before me stripped the exhaust bolts to all hell so when i took them off the studs were shot. Long story short....6 hours later and Carbide drill bit we finally had it fixed....But it ain't pretty.
Old Mar 5, 2007 | 05:11 PM
Soaring's Avatar
Soaring
I ♥ Acer
I don't understand what is smoking. Are you thinking the donuts are smoking somehow? I've never heard of that. Check to make sure you aren't getting oil dripping on the clamp.
Old Mar 5, 2007 | 05:17 PM
sxs191's Avatar
sxs191
I'm thinking the seal's are broken. When the engine warms up the smoke stops. (Just like with the exhaust smoke)
