EFI throttle control
Old Mar 11, 2007 | 01:38 PM
remicks's Avatar
remicks
Default EFI throttle control
I'm converting my '66 I6 to a FI 5.0 and I was looking at the differences between the throttle control. Can I keep my stock throttle controlor do I have to convert it to either a stock V8 throttle controlor a fox body system?
Old Mar 11, 2007 | 07:27 PM
68EFIvert's Avatar
68EFIvert
Default RE: EFI throttle control
You will have to change to a throttle cable. I used the pedal and cable that Lokar is making. Looks sweet and very easy install. I initally tried to use a pedal from a 1970 mustang and then make an attachment on the top to attach the cable to. It would have worked but looked crappy so I scrapped it and made the phone call to Summit for the new pedal. Well worth the money IMO.
Old Mar 12, 2007 | 01:27 AM
JamesW's Avatar
JamesW
I went the cheap/crappy route and modified the 1970 pedal setup. The mod is to add about a 1" extension to the top of the pedal rod, and drill a hole that the plastic retainer will fit.
[IMG]local://upfiles/48409/773C0EAD05FF486F8D57638326B2ADA7.jpg[/IMG]
Old Mar 12, 2007 | 02:47 AM
remicks's Avatar
remicks
Which one is it, I don't see one on summit including a cable
Old Mar 12, 2007 | 11:56 AM
remicks's Avatar
remicks
I see the pedal, did you use the lokar 24 in long cable also? Any other hardware required that I may be missing, thanks for the info.
Old Mar 12, 2007 | 11:59 AM
68EFIvert's Avatar
68EFIvert
I don't remember the part number but all I did was call Lokar and they told me all the parts I needed and then I ordered it via internet. Call 877-469-7440 they are very helpful.
Old Mar 12, 2007 | 12:08 PM
remicks's Avatar
remicks
Thanks for the help, hopefully I'll get everything figured out and all the parts staged before I get back to the states.
Old Mar 12, 2007 | 01:45 PM
68EFIvert's Avatar
68EFIvert
I forgot to tell you the cable you need is the same as the 87-93 EFI Mustang. I don't think they sell in as a cable and pedal kit you will have to buy it individually. I also put on the matching brake, clutch and washer fluid cover. It looks great! I would send you a picture but I took it apart to send off to paint.
Old Mar 13, 2007 | 02:54 AM
remicks's Avatar
remicks
Hopefully the aluminum will look better than the junkyard special set of pedal assembly I have from a fox body.
mrtrodonet
Sep 19, 2020 03:12 PM
UrS4
Oct 3, 2015 06:23 AM
breaking
Oct 2, 2015 01:27 PM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
