9" rear axle
Old Mar 11, 2007 | 02:15 PM
justin_lamore's Avatar
justin_lamore
Default 9" rear axle
I have a 1965 fastback mustang and I was wondering if some of you could direct me to a website that sells new or rebuilt 9" rear axles.
Old Mar 11, 2007 | 02:20 PM
white69mach1's Avatar
white69mach1
Default RE: 9" rear axle
go to the junkyard get one and bring it to a axle shop
Old Mar 11, 2007 | 03:02 PM
latamud's Avatar
latamud
http://www.currieenterprises.com/ces...R.aspx?id=1325
Old Mar 11, 2007 | 03:06 PM
Bentworker's Avatar
Bentworker
http://www.moserengineering.com/
http://www.moserengineering.com/Page...ous-ford9.html
I'm not familiar with the pre 71 Mustangs, but you can find a 71-73 9" easily, but it would need to be narrowed to fit into an earlier car.
Old Mar 11, 2007 | 04:45 PM
67t5ponycoupe's Avatar
67t5ponycoupe
there is some good info in the FAQ about that 9" rears. It will tell you what cars you can get a factory 9" from and make it work. I believe the late 50's full size fords will work.
Old Mar 11, 2007 | 05:01 PM
sweet 65's Avatar
sweet 65
how much are you looking to spend? I have a 9 inch versailles with a rebuilt center and trac loc and 3.70 gears. I might be willing to let it go.
Old Mar 11, 2007 | 05:37 PM
justin_lamore
I actually took the advice of going to the junkyard and picked one up out of an old cougar for 300.00 that will fit right up with mine. I did however, check out the websites and they gave me some great ideas. Thanks everyone for your help.
Old Mar 11, 2007 | 05:45 PM
gothand's Avatar
gothand
ORIGINAL: justin_lamore
How much to have it re-built and all new brake hardware? I'd prefer to have have new bearings and seals installed and wouldn't use it without all new brake hardware.
Good luck!
Old Mar 12, 2007 | 08:36 AM
andrewmp6's Avatar
andrewmp6
if you want a 9 inch and a bolt in 4 link http://www.mustangdepot.com/OnLineCa...ion/4_link.htm 1659 dollars for it and its still needs the diff axles bearings brakes or http://www.mustangdepot.com/OnLineCa...ts/housing.htm but youll still need the diff bearings axles let us know which one you go with
Nov 10, 2015 11:39 AM
firecoyote
Sep 27, 2015 02:37 PM
PB Pod
Forum Issues and Feedback
Sep 17, 2015 08:32 PM
Sep 10, 2015 08:39 PM
Dragonus18
Sep 9, 2015 01:21 AM
