Transbrake question
Old Mar 12, 2007 | 03:40 PM
eholzer07's Avatar
eholzer07
Default Transbrake question
So i bought a rebuilt upgraded C4 from a company on ebay and it has a transbrake. The problem is that i didnt upgrade my shifter. I have the original c4 shifter in it. The question i have is what would you do about the transbrake. I need to install a switch somewhere to run it so i was just wondering where you guys would mount that. one the dash? is there anyway that i could mount that somewhere near the shifter. If you have done something creative let me know
Thanks
Eric
Old Mar 12, 2007 | 05:40 PM
THUMPIN455's Avatar
THUMPIN455
Default RE: Transbrake question
Is it forward or reverse pattern? Also most transbrakes are a full manual valve body and some dont have engine braking available.. its a full race piece, not so much a street piece. The shifter needs depend on the type of valve body pattern it has
You need a switch to operate the brake. You dont want to use it while sitting at a stoplight, but you will be able to find the ultimate stall speed of your converter..
Old Mar 12, 2007 | 09:52 PM
LCC's Avatar
LCC
My AOD has had a trans-brake since 1990, Full automatic with manual select. My wife can put it in D and go for a cruse, as for me I likebanging through the gears. I would recommend a switch and a button. Mine are mounted to the shifter box, I arm the trans-brake and hit the button at the light, then hammer the gas, light goes green and let go of the button, reach for the gear and shift. The thing to be careful is not to hit the brake after you start moving.....boom.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
