64.5 Power Steering HELP ME!!!
Old Mar 14, 2007 | 10:08 PM
MrMainEvent24's Avatar
MrMainEvent24
Default 64.5 Power Steering HELP ME!!!
I've been having a problem with it for a little while. I have a silver resovoir in the front-right of the engine compartment with a pink fluid inside it. I opened this while the car was running, and the pink fluid was rushing all over inside.
1. Is this pink fluid power steering fluid?
2. Should it be moving around when the car is running?
3. Are the hoses going from the pump to the control valve high pressure hoses? or can I just unscrew them and take them off?
PLEASE HELP ME!
thanks
Old Mar 15, 2007 | 03:01 PM
MrMainEvent24
Default RE: 64.5 Power Steering HELP ME!!!
Any help?
Old Mar 15, 2007 | 03:05 PM
gothand's Avatar
gothand
The fluid is red and looks like automatic transmission fluid. My power steering pump (I have an '85 pump in my '65) uses ATF type F. You will see it swirling around in there. Make sure the fluid level is where it should be.
Of of the pump, you have two hoses, one high pressure and one low pressure. It should be obvious which is which. The high pressure is threaded on to the pump and the low pressur is a push on.
Is you power steering not operating properly or were you just looking to learn more about it?
Old Mar 15, 2007 | 08:03 PM
bob emmerich's Avatar
bob emmerich
Yep. I'd have to agree. Ford specified Type F auto trans fluid in thier p/s systems for years. It should be swirling when the pump is running. Low and high pressure hoses, however I wouldn't remove them unless the engine is off.
Old Mar 16, 2007 | 09:32 AM
MrMainEvent24
My power steering is not working properly. When I turn the wheel it makes a horrible sound. I was told that one of the pump hoses was rubbing against the lower control arm and this slowly separates from the control valve. Apparently this causes a slow leak, but I do not ever see any fluid?
It looked a little low on fluid, but I am not sure how it would get that low since I filled it up about a month ago. Do you guys reccommend doing anything with the hoses?
Old Mar 17, 2007 | 12:28 AM
aj05must's Avatar
aj05must
does it make a horrible sound when you turn the wheel slightly or only when its turned all the way?
Old Mar 17, 2007 | 10:36 PM
MrMainEvent24
Both - When turned slightly and when turned all the way. I think it has something to do with the hoses.
How do I fix this?
CS2007
Jun 25, 2019 09:45 PM
jrrhd73must
Oct 2, 2015 09:17 PM
KingRando
Oct 2, 2015 08:06 AM
Sep 25, 2015 06:58 PM
