Carb tuning...
Old Mar 16, 2007 | 01:43 AM
connor90's Avatar
connor90
Default RE: Carb tuning...
[sm=funnypostabove.gif]
Old Mar 16, 2007 | 01:49 AM
Colorado_Mustang's Avatar
Colorado_Mustang
I used an Edelbrock carb for about a year. Thought it worked pretty well. Then I put on a Holley 600 VS. Instantaneous power improvement and much better throttle response....without tuning. I now only run double pumpers, which I found to be much better than the vacuum secondary carbs at higher altitudes.
Old Mar 16, 2007 | 01:58 AM
connor90's Avatar
connor90
ya i have an edelbrock on mine because that's what it came with...i think its like a 650 or 600 cfm and i will probably end up switching to like a 550 cfm holley wheni run out of stuff to keep me busy.
Old Mar 16, 2007 | 02:05 AM
THUMPIN455's Avatar
THUMPIN455
Simply astounded by some replies here..
None to fond of the E carb either. Get a book on tunning, You can read it there in depth and get correct info.
E carbs DO NOT have a power valve and the only way to open the secondaries faster is to lighten the counter weight on the air valve shaft.. The idle mix screws do NOTHING after even a little throttle angle, they are for the IDLE only. Jets and metering rods are the way to change the fuel curve with an E carb. Unless you can read a plug effectively you will not get the jetting right, possibly close but not right.
Timing is to a point trial and error, the factory setting is a good starting point, but you can still have an inaudible(that means youcant hear it) ping. Inaudible ping will destroy an engine as easily as a very loud one. There are many variables that cause pre ignition, some of them are oil in the cylinders from tires valve seals and rings, heavy load, temperature of air and coolant, combustion chamber design, carbon buildup, altitude, and a few others. Just because one engine can idle around with race gas compression doesnt mean the one in your car can.
Get a book, get educated that way the incorrect info wont screw up your car or cost you more money.
Old Mar 16, 2007 | 02:08 AM
connor90's Avatar
connor90
haha ya, im pretty much lost when it comes to tuning a carb so i think i might take it somewhere and have someone who has the proper tools and know what they're doing tune it
Old Mar 16, 2007 | 02:35 AM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: THUMPIN455
I went to the grocery store today, and noticed a small amount of liquid black fluid coming out of my exhaust. Am I in trouble?
Old Mar 16, 2007 | 02:36 AM
mikethebike's Avatar
mikethebike
Right...they don't have a 'power valve' per say, but the metering rods that are controlled by vacum do the same thing as a power valve...they enrichen the mix during periods of low vacum. And to address the 'you won't get it right' statement....well....nobody can read plugs THAT well and the only way to 'get it right' is with an EGT guage.
Old Mar 16, 2007 | 07:55 AM
KBunny's Avatar
KBunny
Lets completely rule out Ignition since the Plugs, Wires, Coil, and Distributor (Mallory Unilight Electronic Distributor) are all brand new and I am not the average teenager who is an idiot when it comes to setting the timing and getting the right vacuum port (and factory spec is 6BTDC without vacuum advance hooked up which should be adequate since my engine is stock as far as I know).... now I am not sure weather or not the distributor has a mechanical advance since I didn't check, didn't see one, but the site I ordered it from said it did... I will try a couple different timing settings but I know that its not going to change anything...
What Thumpin said about oil burning could be a possibility since I do burn oil, weather its rings or valve guide seals I don't know.
Old Mar 16, 2007 | 12:59 PM
my77stang's Avatar
my77stang
The distributor also has weights/springs in it to mechanically advance timing... it could be that you threw a weight or something
by chance is a spring broke or came off it would advance your timing right away.
Instead of bashing the equipment that KBunny and many other people on this board (including myself) have
sorry i wasnt trying to bash anyone in particular - and i like some of edelbrocks products very much. (i have their fuel pump and intake on my car) but i am not too fond of their carbs.
and for what its worth there HAS to be a reason holleys are the carbs used in virtually all vehicles in top notch applications such as..
yes, im a smart *** [8D]
Old Mar 17, 2007 | 01:36 AM
mikethebike
ORIGINAL: KBunny
Was not aware anyone called you an idiot. But just to refresh your memory...ALL distributors built for pre-smog engine have a mechanical advance and on the Mallory Unilitem (I ran one in 1975 on BOS-302) have an ADJUSTABLE mechanical advance. The trouble is not the carb...it is either the advance curve or carbon build-up.
