Wheels to fit Granada discs
ok well i was looking for new wheels for my car and ran across a good deal on some magnum 500's. they are used and the owner says that he thinks they are 14's. so im wondering, would those work. i know the styled steel 14's dont but i have some 14" slotted mag's on my car right now that do. i thought i remember someone mentioning that the 14" magnum 500's will fit because they are made to fit disc brakes.
thanks
thanks
Mine are 14" Magnums with the granada conversion. Had to put a very small spacer behind the wheel though. The calperps barley rubbed. Probably could have ground just a hair off of them and they would have worked without the spacers though.
I am runnning styled steel 14's on my 66 coupe and wanted to know...
Is there ANY disc conversion that will work with what I have, or do I need to look at new wheels if I want disc brakes???
Thanks
Thanks
Dennis says my 14" Mag 500's MIGHT work with his swap, but won't guarantee it. I am going to take a wheel to him and see if it will. He does say that a 15" wheel will work though. So, if you are considering the disk swap and want new wheels, go with nothing less than a 15" wheel. I fully expect to have to use a thin spacer.
ya i couldnt remember if i read that or not. im pretty sure i read somehwere that you could grind a little off the top of the caliper to make it fit. i already did the conversion and i found someone who would sell me some used magnum 500's for relatively cheap compared to new wheels plus it includes tires too. i might just get them and if they dont fit ill just sell them to someone else.
Are the Granada discs larger in diameter/the calipers that much bigger, or a combination of both over the stock disc brakes that came on our cars? The reason I ask is my '65 Fastback came with factory disc brakes, and the stock 14" rims fit without issue.
Aux
Aux
