Help installing a new gear
Old Mar 19, 2007 | 01:09 PM
bluestanger66's Avatar
bluestanger66
Default Help installing a new gear
I have decided to go with a 3.55 gear for my 4 sp 66 mustang fastback. how difficult is that to install? can i do it? or should i take it to a shop? thanks! i have the tranny and drive shaft off already. thanks!
Old Mar 19, 2007 | 01:17 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Help installing a new gear
Without the knowledge and special tools, you won't be able to change it yourself. Take it to a shop.
Old Mar 19, 2007 | 02:00 PM
gothand's Avatar
gothand
Soaring nailed it! Incorrect pinion depth and backlash will make your expensive parts junk. If you're trying to save some bucks, remove the axle retainer plates, pull out the axles about 4", unbolt the third member from the housing and take it to the shop. You should be able to get your labor charge cut in half that way. Another option is to pick up a third member already set up with the gears and differential you want.
Old Mar 19, 2007 | 06:02 PM
DonA's Avatar
DonA
Not to be a wise guy, but if you have to ask you can't do it.
The job requires training and practice and special tools.
Follow the previous good advice.
[align=left] [/align]
Granatelli Sales
Jan 20, 2020 12:34 AM
musnicki
Sep 23, 2015 07:11 AM
TimeLord101
Sep 4, 2015 09:27 AM
cbird1177711
Sep 3, 2015 08:43 PM
Sep 3, 2015 07:14 PM
