Temp control cable...Broken Pawl
Old Mar 19, 2007 | 02:29 PM
68vertible's Avatar
68vertible
Default Temp control cable...Broken Pawl
Has anybody figured out a "good" way to fix this?
The pawl that screws onto the control box mechanism is broken off of my control cable and I can't seem to come up with a way to fix it. Its the only leverage point to hold the cable in place to switch between heating and cooling...
I have a 1968 convertible, 289, Auto tran, Factory AC...Lime Gold w/Light Parchment interior
Have spent the last 6 years rebuilding it...will get some photos up soon
Old Mar 20, 2007 | 02:23 PM
crunchyskippy's Avatar
crunchyskippy
Default RE: Temp control cable...Broken Pawl
I'm not exactly sure of what you're referring to. Can you posta picture?
However, about a year ago I broke the plastic piece that clamped the cable housing to the control panel. I'm guessing this is the same thing you're talking about. I certainly couldn't figure out how to fix it with glue/epoxy/etc...
I ended up buying a set of new heat, vent, defrost cables (3 for my 67 w/o ac) for about $30. The only place I could find that carried it was something like John's Mustang out of Texas. I'll see if I can confirm that is the correct place.
I had to stand on my head to hook up the new ends to the heater plenum, but it works great now. Also, if I recall correctly I think the replacement was metal instead of plastic.
Good luck.
mrtrodonet
Sep 19, 2020 03:12 PM
UrS4
Oct 3, 2015 06:23 AM
breaking
Oct 2, 2015 01:27 PM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
