ENGINE SWAP
Old Mar 19, 2007 | 08:47 PM
MIKKO's Avatar
MIKKO
Default ENGINE SWAP
Hi. I havew a 67 mustang that came with a 200 6 cyl engine that i want to convert over to a 302 or 289. My question is what am i going to need to do this swap. I have the C4 trans off of the original 6 cyl. I also have a 302 sitting around from a 81 ford truck. Will the C4 be strong enough for the 302 or will i have to get a new transmission. If it will work what willI need to bolt them together?Torque converter? Bell housing? Or would it be easier just to find an engine and transmission that came together . I am up grading the rear end to a 9 inch and installing disk breaks in the front from CSRP i think. I am also quite sure that i dont have to upgrade anything else on the front suspension other than the springs. If i am wrong please correct me.
thanks
Old Mar 19, 2007 | 09:43 PM
Aussie66Fastback's Avatar
Aussie66Fastback
Default RE: ENGINE SWAP
the C4 should handle the 302 no problem
if you have 4 lug wheels you'll want to change those too.
Yes correct on the springs and probably shocks too. Other upgrades depend on the condition of existing steering components, ball joints etc
there is lots of information on this topic in the FAQ section...it gets asked every week!
I suggest you look there first.
Old Mar 19, 2007 | 09:45 PM
Soaring's Avatar
Soaring
I ♥ Acer
Here is the FAQ. Loook under engines/engine swap/fuel delivery.
https://mustangforums.com/m_732643/tm.htm
Old Mar 19, 2007 | 11:49 PM
andrewmp6's Avatar
andrewmp6
to do it right engine tranns a 8 inch or 9 inch rear end the brakes springs and shocks
Old Mar 20, 2007 | 01:00 AM
sweet 65's Avatar
sweet 65
If you are still planning on comming down this saturday, I may have all the parts you need to do your swap as well as the versailles. message me again, I can try to hook you up with anything else you need.
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
97SN95GT
Sep 13, 2015 09:45 PM
zachary1988
Sep 4, 2015 03:04 PM
Sep 1, 2015 08:16 PM
