back up lights
Old Mar 22, 2007 | 11:08 PM
mySAVIOReigns's Avatar
mySAVIOReigns
Default back up lights
Well, my back up lights aren't working. That should be the last piece to the puzzle to get it inspected. I checked the bulbs, and they look okay (the coil is not broken like in a regular light bulb). What else should I check? All of the other lights work, so I'm a little confused. Underneath the car, the connector/wires going to the pigtail are covered in some kind of grimy dirt, that might be it? Any help is appreciated, thanks
Old Mar 22, 2007 | 11:14 PM
Cogtx's Avatar
Cogtx
Default RE: back up lights
Do you have a manual transmission with switch mounted to top of tranny? If so, does the linkage make contact with the backup light switch when you put it in reverse? Check the voltage at the backup light itself to see if you are getting any juice...try this first...keep us informed...
BTW...backup lights not needed to pass inspection in the the Great State of Texas...but back license plate light is needed...
Old Mar 22, 2007 | 11:27 PM
mySAVIOReigns
No, I have an auto.
Backup lights are not needed to pass? Really?
Old Mar 22, 2007 | 11:45 PM
Cogtx's Avatar
Cogtx
ORIGINAL: mySAVIOReigns
No, I have an auto.
Yep, not necessary for inspection here in Texas. We've been missing the backup light switch for 3 years now and have had no prob with inspections. Those backup light switches get pricey..around $50...so I just keep looking on ebay until I can found a cheap one...
If you have an auto tranny, I think the backup light switch is near the shifter (?)...Maybe check it out to see if it is good...maybe someone else with an automatic can chime in on this..
Old Mar 22, 2007 | 11:53 PM
mySAVIOReigns
Did the 66 come with a license plate light? I didn't think I saw one back there. Crap, I don't want to mount that lol
Old Mar 22, 2007 | 11:57 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yes, the 66 came with a license plate light, and they will definitely inspect it to make sure it works.
Old Mar 23, 2007 | 12:25 AM
ideal_mustangs's Avatar
ideal_mustangs
The backup lights aren't required in VA either. Just so long as both of them aren't working.
Old Mar 23, 2007 | 01:01 AM
mustanglover66's Avatar
mustanglover66
Backup lights are not needed in MD or NC mine haven't worked in about 10 years.
Old Mar 23, 2007 | 03:32 PM
LCC's Avatar
LCC
On the side of your trans there is a round, white plastic part that has the back-up light switch and the nutural safety switch on it. You mghit have to replace the whole part or just remove it from the trans and test it out of the car to se if its the problem..
Old Mar 23, 2007 | 10:48 PM
mySAVIOReigns
Thanks, I will check that in the morning, and also, I got the license plate light fixed. Thanks guys
