289 vs. Hi Po 289
ORIGINAL: my77stang
no prob man i just saw an oportunity to correct ya and poke a little fun all at once so i had to take it[8D]
K motors differed from standard motors with the following:
1. High nodular content crank
2. Thicker webbing in block
3. Larger main bearing caps
4. Larger connecting rods
5. Forged pistons
6. Solid lifter cam
7. Dual-point mechanical-only advance (hence the 12 degress initial advance)
8. Screw-in rocker studs
9. Cast-in valve spring seats
10. 54 cc(?) combustion chambers
11. Better exhaust manifolds
Some people want to believe the heads had different porting but they didn't.
I may have left something out. I'm getting old.
5. Forged pistons
6. Solid lifter cam
ORIGINAL: Soaring
Actually, there are three 289 Mustang engines. The C code is a 2 barrel carb version and was listed at 200 Horsepower at the flywheel. The 4 barrel A code 10:3.1 compression version was listed at 225 HP. The Hipo is listed at 271 HP. This should answer your question of what is so special about the K code hipo engine.
http://www.hipomustang.com/images/hipoeng/
I keep forgetting that the '64-1/2 had a different code for the 4-barrel.FWIW, my factory service manual lists the 4-barrel at 10.0:1 and the 2-barrel as 9.3:1. I didn't realize the compression ratio was different. Learn something new every day ... but forget twice as much as I learn. [sm=alcoholic.gif]
Well, I wasn't born yet in '65 so I wouldn't know what Ford said. What I do know is that I own a '65 K code and the K code book written by Tony Gregory even says they didn't have forged pistons.
ORIGINAL: Soaring
That seems to be happening a lot lately. What am I, the fall guy?
ORIGINAL: my77stang
