Battery kill switch/disconnect
Old Mar 24, 2007 | 12:56 AM
mySAVIOReigns's Avatar
mySAVIOReigns
Default Battery kill switch/disconnect
I've been looking for a remote battery kill switch. I don't want to really spend like 30-60 bucks. (the $30 ones look like crap, and the $60 ones are too expensive). How hard is it to just build one of these? Anyone done anything like this?
Old Mar 24, 2007 | 01:43 AM
az1966's Avatar
az1966
Default RE: Battery kill switch/disconnect
Never done one,,I just put a switch in the left upper kick panel for the NEG wire to the coil and throw it before I get out to make sure it slows up the thiefs
Old Mar 24, 2007 | 01:55 AM
andrewmp6's Avatar
andrewmp6
do you just want one for a anti theft or dragracing i have a flaming rivers one mounted in my tail light pannel was 93 bucks from summit. if you make one make sure the switch and wires will handle the power. my best trick at anti theft is if you have a electric fuel pump wire it to a oem switch on the dash they wont ever find it
Old Mar 24, 2007 | 01:59 AM
mySAVIOReigns
Well that seems a lot easier Yea, I just want it for anti-theft.
So, I'm guessing: You ran a 12V wire to a fuse, then that to a rocker switch. Then that to the ignition? Seems too easy
Old Mar 24, 2007 | 02:04 AM
green_blurr's Avatar
green_blurr
Or you could wire the 12v plus to your tank and when you get out, throw a switch so that it bridges it to a ground so if the wrong person gets in and doesnt hit the switch before they turn the key over sending current through the wire to the tank ---KABOOM !
kool safety device that person will never steal another car again
Old Mar 24, 2007 | 02:07 AM
mySAVIOReigns
lol, yea, that sounds like a reasonable solution. Prevent theft, lose car
Old Mar 24, 2007 | 02:09 AM
andrewmp6's Avatar
andrewmp6
my fuel cut off was just spliced in to the wires for the pump heres the cheapest one id use http://www.12voltguy.com/e-commerce-...0.html5.0.html
BOB ROME
Jul 26, 2023 01:54 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
logan409
Sep 26, 2015 07:43 PM
Art161
Sep 9, 2015 10:33 AM
