headers
Old Mar 24, 2007 | 04:41 PM
papi_chulo's Avatar
papi_chulo
Default headers
what headers will open up my engine to some better horses.
Old Mar 24, 2007 | 04:44 PM
676869Stangs's Avatar
676869Stangs
Default RE: headers
Long tube are the best, shorties don't offer as much gain. You just need to make sure they will clear any steering issues. BTW Tri-Y = long tube in case you hear that term. I like the ceramic coated, but that is personal preference.
T
Old Mar 24, 2007 | 04:45 PM
easttennmotors's Avatar
easttennmotors
Default RE: headers
hooker super comp if your really hard on it or 350+hp, you can get custom headers $$$$, but for stock to modifiedstreet engines i would say tri-y headers are your best bet...
Old Mar 24, 2007 | 10:46 PM
longlive289s's Avatar
longlive289s
Default RE: headers
depends on your price range. tri-y's are your best bet but u can keep the stock look (sorta) and get hi-po k code manifolds. u can spend as stated bucks on hooker super comps or u can do as i did and just get the comps which are half the price. make sure u get ceramic so the headers dont look like poo after a couple thousand miles. also helps with heat problems on the poor starters since the headers will drop right down next to em. if u dont u do need to get a heat shield for the starter....or at least id advise it
Old Mar 24, 2007 | 11:27 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: headers
I was at a show one time, and asked a Mazda rotary engine guy if he had headers. Sure enough, he said he did. Basically, the higher the price of the headers will give you longer and better service with more HP gain. The ceramics reduce the amount of heat in the engine compartment, and that is important on our old engine compartments where cold air induction is difficult to achieve.
Old Mar 25, 2007 | 01:53 AM
mikethebike's Avatar
mikethebike
Default RE: headers
ORIGINAL: Soaring
A company in Canada makes a cold air system that used 4 in round hoses mounted in the radiator support. Can't remember their name but they advertize in most of the magazines. You should give them a look.
Old Mar 25, 2007 | 02:40 AM
easttennmotors
Default RE: headers
i still wrap my headers personally, even the hooker truck headers i have on my durango...
Old Mar 25, 2007 | 02:41 AM
longlive289s
Default RE: headers
ORIGINAL: Soaring
instantly reminded me of this guy and his "special edition" rotary mustang with pistons [sm=chairshot.gif]
http://videos.streetfire.net/search/...ce38c2d1d7.htm
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Roxon68
Mar 17, 2016 08:13 PM
junior04
Sep 28, 2015 10:53 AM
trashxtrash
Sep 20, 2015 10:49 PM
BrantleyS550
Sep 14, 2015 04:18 PM
