Starter Grinds
Old Mar 25, 2007 | 09:46 PM
morg68stang's Avatar
morg68stang
Default Starter Grinds
Sometimes when I'm starting my car the starter acts like it doesn't catch and makes a God awful grinding noise which is the best I can describe it.It's kind of the sound you get when you try to start you car after theengine is already running. I have to turn the ignition a few times to get it to work right. Is this the starter going bad? Improperly installed?
Thanks,
Old Mar 25, 2007 | 09:48 PM
66 stang's Avatar
66 stang
Default RE: Starter Grinds
are you sure its coming from the starter, cuz when my battery is dead or dying, the solenoid makes a noise that sounds terrible, and makes me think there is something really wrong with the car.....
Old Mar 25, 2007 | 09:56 PM
Soaring's Avatar
Soaring
I ♥ Acer
It's pretty hard to mix up the two sounds. The solenoid makes a buzzing or clicking sound, whereas the bad starter has a grinding sound. My advice would be to take the starter off and take it to a parts place and have it checked. It's only two bolts and unhooking the battery at the starter to get it out. Mine did that last summer, so I took it in to have it checked, and sure enough the bendix had gone south. Oh, and if you take the starter out, be sure you unhook the battery cable at the battery before you do.
Old Mar 25, 2007 | 09:59 PM
LCC's Avatar
LCC
Sounds like the Bendix on the starter is not allowing it to engage properly. I would replace the starter before your flex plate gets chewed up...
Old Mar 25, 2007 | 10:04 PM
Soaring's Avatar
Soaring
I ♥ Acer
And, if you have a manual transmission, tell the clerk to give you one for an automatic. Trust me on this. Been there, done that. If you order one for a manual tranny, the casing will be too fat to fit in the hole. The nose on the two are the same. The one for an automatic fits perfectly. Yeah, I know that goes against the grain, but it is true.
Old Mar 26, 2007 | 03:42 PM
boogerschnot's Avatar
boogerschnot
You could get down there and check to see if its tourqued in correctly,, If its loose the gears might not be meshing right... Just check it.. if thats good then pull it and check it at a parts store... ok.
Old Mar 26, 2007 | 05:32 PM
my77stang's Avatar
my77stang
could be the bendix not engauging all the way
could be the starter has came loose
could be the flywheel / flexplate has a bad spot on the teeth (which you can inspect and see)
could be the starter needs a shim
my personal choice is in bold though
Old Mar 26, 2007 | 05:35 PM
Derf00's Avatar
Derf00
Gentleman's Relish
+1 on the flexplate having a bad spot. Intermittent as your problem is. Undo the inspection plate and take a look.
If you pop the starter off, it's probably caked with oil/grease. Use an electrical parts cleaner to clean it out. You should be able to pull the bendix out free hand unless it is "glued" in place. Spinning it is another story. Even new ones don't rotate that easily by hand.
Old Mar 27, 2007 | 01:52 AM
morg68stang
So, where is the inspection plate for the flywheel? Can I see it just by taking the starter off?
Old Mar 27, 2007 | 01:58 AM
Tony R's Avatar
Tony R
I have had a broken tooth on a fly wheel before and it had the same symptoms. When you pull your starter you will be able to see the teeth on the flywheel. you may want to have a buddy turn the motor over by hand while you look at the teeth. Make sure you disconnect the battery.
