drivetrain questions
Old Mar 25, 2007 | 11:43 PM
dcohen's Avatar
dcohen
Default drivetrain questions
so, im assuming my 1966 mustang (factory 289)has the 8.8in rearend, my question is
How much power can i put to this thing? what gears should i run
my drivetrain plans include a 430hp 444ft/lbs. torque 347 stroker and a t-5 /t-56 transmission
is a t-56 a 5 or 6 speed? what 5 speed trans will hold up to the kind of power im looking at?
Old Mar 25, 2007 | 11:57 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: drivetrain questions
You don't have an 8.8 rear. You have an 8" open rear if it is stock. The 8 inchers are good to go up to about 400 or so HP if you don't beat the **** out of it. The gears you add will depend on what you will be using the car mostly for. For a street rod, the 355's are the best of both worlds. Take it to the track often, and you will need 410's. Now, if you are thinking about 450+ horsepower at the wheels, you will need at least a 9" rear with a locker or at least a posi traction.
Old Mar 26, 2007 | 12:24 AM
sweet 65's Avatar
sweet 65
t-56 is six speed, you may want to steer clear of the t5 though, I was looking into getting one for a while and they are not any good for high horsepower applications. You will want to go with a tko, at least the 500 model but possibly the 600 just to be safe if you want a 5 speed. I would go with a 9 inch like soaring said but if you are going to have a t56 you may want to think about 3.70 gears because it should give you good gearing but not eliminate the use of first gear at the same time (depending on which t56 you get). In that 9 inch, make sure you get at least trac loc if not a spool (depending on your application). There is a lot of options out there so make sure to research plenty and figure out what you want. Remember at the same time that cheaper is rarely better when buying car parts and the t5 is just that; cheaper.
Old Mar 26, 2007 | 01:50 AM
Scott H.'s Avatar
Scott H.
Old Mar 26, 2007 | 03:11 AM
andrewmp6's Avatar
andrewmp6
does anyone make stronger axles for the 8 inch if they do id rebuild it 8 try to keep it close to stock/matching numbers as you can
Old Mar 26, 2007 | 01:35 PM
iamdiffrnt's Avatar
iamdiffrnt
IIRC, the axles aren't the problem with the 8" in fact they are the same as 28 spline 9" axles. The problem is a weaker pinion set up in the carrier. While you can spend the money on a stronger aftermarket carrier, You could spend about the same money and have the stronger 9" axle assembly. [sm=smiley13.gif]
Old Mar 26, 2007 | 02:08 PM
JMD's Avatar
JMD
ORIGINAL: sweet 65
Regarding the TKO 500 or 600, I would go with the 600. All of the prices I have seen for these transmissions (new) only differ by about $100.00, that being the case you will get an extra 100 lbs of torque capacity for about a dollar a pound.
Old Mar 27, 2007 | 01:14 AM
dcohen's Avatar
dcohen
is the tko 500 a 5 speed?how hard would it be to swap a t-56 in?
Old Mar 27, 2007 | 03:28 AM
JMD's Avatar
JMD
ORIGINAL: dcohen
I have heard it is really easy, I have not done it,,,, yet,, will be doing it in the next couple of weeks.
<<oh , and the tko 500 is a 5 speed>>
Old Mar 27, 2007 | 03:42 AM
green_blurr's Avatar
green_blurr
All this hype on manual trannys is great, but is there a good aod automatic tranny that can be used for everyday use but still retains the power for hot rodding the streets?
