starter problems
Old Mar 27, 2007 | 08:12 PM
eZ's Avatar
eZ
Default starter problems
well the accessories turn on when i turn the key to the on position. but when i try to turn turn the motor over there is nothing...its a brand new starter. car will start when i hot wire it.
[/align]
Old Mar 27, 2007 | 08:44 PM
Rorin67's Avatar
Rorin67
Default RE: starter problems
So it will start if you jump the positive battery post to the large wire running to the starter on the solenoid? If that's not how you are "hot-wiring it", then we'll need more info.
If that is it,then it could either be a bad starter solenoid or a bad ingition switch (or a bad electrical connection anywhere along that line...).
Electrical problems are always fun... [:'(]
Old Mar 27, 2007 | 08:59 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah we need some more info. It's sounding like an ignition switch thusfar, but not sure.
Old Mar 27, 2007 | 09:30 PM
eZ's Avatar
eZ
i think i figured out the problem. there is no neutral safety switch hooked up to the AOD...
[/align]
Old Mar 27, 2007 | 09:33 PM
eZ's Avatar
eZ
if there is not one hooked up it would create this problem right?
[/align]
Old Mar 27, 2007 | 09:48 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yes, and I am not sure how you would hook it up, but that is your problem. One thing I know for sure is that you don't want to eliminate/ bypass the neutral safety switch if at all possible.
Old Mar 27, 2007 | 09:50 PM
eZ's Avatar
eZ
ya after bypassing the switch it will start now i just need to find how to hook it up properly
[/align]
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
jaiidutch
Sep 14, 2015 10:29 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
