frozen bolt
wait a while for the gear to get in then try tightening it first to crack the rust seal and/or give the bolt head a couple of taps with a hammer.
make sure you have the right size wrench for a good fit so you dont strip the head of the bolt
if that fails lean on it harder...remember "if it jams, force it. If it breaks, it needed replacing anyway."
ORIGINAL: easttennmotors
Go get a 1/2 in drive breaker bar, on of the best investments you can make tool wise if you work on cars imo
Yeah, can't tell you how many times i've used a breaker bar....or even stuck some pipe on the end for some MANLY leverage.
But +1 on giving her a love tap with the hammer, and the heat trick; both usually work well. When heating be sure to only heat the bolt so only the bolt expands, other wise your not helping yourself any.
Sometimes the different metals will cause them to seize. An aluminum alternator housing and a steel bolt can corrode together. Try some heat from a torch around the housing near the bolt it works for us at our shop. Caution: Aluminum can't be heated like steel without melting it so be careful.
