Welding primer?
Old Mar 28, 2007 | 04:39 PM
baddog671's Avatar
baddog671
Default Welding primer?
I know when you normally weld you clean the surfaces to bare metal, weld, and then can paint them but how does "weld-through zinc" primer work? Can you prime the metal and literally weld through the primer, insuring everything is all primed and nice?
Old Mar 28, 2007 | 05:11 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Welding primer?
If parts need to be primed, 3M makes a product called “weld-through primer†which will conduct the electrical current while providing protection to the bare metal.
Old Mar 28, 2007 | 05:25 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
+1 yeah its well worth the money spent to help cut back on corrosion and a god epoxy to seal everything up or an encapsulator like por15 or rust bullet
Old Mar 28, 2007 | 05:51 PM
baddog671's Avatar
baddog671
so aslong as the metal is clean of junk but is fully primed with this stuff, it will weld just like normal? The stuff I got even has a Mustang on it
Old Mar 28, 2007 | 07:53 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: baddog671
Yep.
Old Mar 28, 2007 | 10:35 PM
jaw66's Avatar
jaw66
They make two types of weld thru rattle can and brush on. I prefer the brush onit isnot as messy. When you go to do your welding scratch in the plug weld area or where you are going to solid weld with a pick or something. You want to remove the the coating from that area. If you weld right to the zinc it will not be as strong of a weld. Also make sure any galvanized coating is removed if not you will not get a clean weld. Hope this helps......
Old Mar 30, 2007 | 08:44 PM
restomod67's Avatar
restomod67
ORIGINAL: baddog671
My experience has been that it will not weld just like normal. It will weld, but will not duplicate clean metal to clean metal ease of welding. I usually wire brush the primer off the exact areas that will be welded and use it to protect the areas direcly around the weld that you won't be able to get to after the welding is done. Honestly, I don't think you can ever protect an area 100% that you can't get to after welding.
Old Mar 30, 2007 | 08:49 PM
boeing747arowair's Avatar
boeing747arowair
good stuff! pricey but nice!!!!!!!!1
Old Mar 30, 2007 | 11:04 PM
67fastbak's Avatar
67fastbak
isnt that what they spray on after youget cars media blasted so you can still do body work but it wont rust
Old Mar 30, 2007 | 11:50 PM
jaw66's Avatar
jaw66
In the paint line I use at work it is called vari-prime for bare metal. Most of your primers today are not a direct to metal application so you need to spray a light coat of vari-prime first at least in the dupont line. Most epoxy primers are direct to metal application. Weld thru is a different primer alltogether. You should remove any primer overspray from the weld thru before applying another primer.
guitarman376
Oct 11, 2015 01:47 AM
cyclop5
Oct 3, 2015 09:21 PM
jrrhd73must
Oct 2, 2015 09:17 PM
Sep 17, 2015 07:57 PM
cardsrus1
19
Sep 15, 2015 08:37 AM
