Starting
Old Mar 31, 2007 | 05:35 PM
stang30's Avatar
stang30
Default Starting
[8D]I recently rebuilt the engine in my 1966 I6. I put it all back together but now it does not start. It will turnover but it will not start. I have a new battery and new plugs. What I am I missing?
Old Mar 31, 2007 | 06:09 PM
kalli's Avatar
kalli
Default RE: Starting
it must be this time of the year again :-) everyone gets the cars out and they don't start
for starting you need 3 things:
a) compression
b) spark
c) fuel/air mixture
to see if you get any air, get rid of the air cleaner, look down the carb and push the accellerator. just to see if it sprays
to see if you get a spark unscrwe on plug, leave the spark cable on the plug as if it wer in the block. hold the spark plugs thread to the engine block to see if it sparks when the engine is turned
to hear if you have compression: what does it sound like when you're starting ? like wwwwwwwhhhhhhhh or rather like whupp-whupp-whupp. the latter is ok. the first is no compression.
let us know what's missing or if it's all there. if it's all there we have to narrow it down. (timing, mixture ....)
Kalli
Old Mar 31, 2007 | 06:12 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
i bet the dist is not in the correct place propbably 180 degrees out did u set it up for tdc? did u make sure it was the intake stroke?
Old Mar 31, 2007 | 06:22 PM
stang30's Avatar
stang30
The car goes whup-whup-whup when it turns.
I am not getting spark. I took the #1 wire off and held a screw driver next to the spark plug to check for a spark.
I am not sure about the position of the dist. I can turn it 180 degrees if you think that will help solve the problem and give me spark.
Old Mar 31, 2007 | 06:24 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
well you should be getting spark even if its 180 degrees out but it will be at the wrong time how are the points and are you getting 9volts to the positive side of the coil with the key on?
Old Mar 31, 2007 | 06:35 PM
stang30's Avatar
stang30
The points are good. I am getting 9 volts when the key is in the on position.
Old Mar 31, 2007 | 06:36 PM
LCC's Avatar
LCC
Check to see if your neutral safety switch is connected backup...
Old Mar 31, 2007 | 06:49 PM
stang30's Avatar
stang30
I will double check but I am pretty sure that it is connected.Thanks for the tip.
Old Mar 31, 2007 | 06:50 PM
kalli's Avatar
kalli
[hr]ez had probs with neutral safety switch and that will cause the engine not to turn.
So your trouble is either distributor or coil.
a) make sure the engine is grounded and if it is check for spark agaion with screwdriver in cable and the screwdriver pretty close to the engine block.
b) as you have breaker points: get rid of cap and rotor and look at breaker. The thing should open AND close when you turn/start the engine.
c) try the old coil
d) the coild should have 3 cables. 1 spark cable going to middle in cap of distri. 1 should carry + when the ignition is switched on and the third is the one leading to breaker.
Old Mar 31, 2007 | 08:57 PM
Soaring's Avatar
Soaring
I ♥ Acer
Anybody know the firing order for that I200? Check that. If you are getting absolutely no spark, then your coil could be dead, or your points aren't opening and closing. Double check the points seetting. I don't know what it is.
