C4 tranny ?'s
Mach I Section Moderator
I dont know much about the tranny to start with only what i've been told, so i dont know if its really gonna do anygood to ask, but how much power can a c4 with a shift kit, and a 3000-3500 stal converter, and its been "beefed up", handle?
The stall doesn't have too much to do with how much power it can handle. The "beefed up" you are refereing to isn't very specific. There are always heavier bands, shift kits etc. I do know of guys who would replace the planetary cluster and put them behind big blocks. Basically anything is possible depending on how much you want to spend. Unless you are extremely concerned with weight and you are worried about druability you could always step upto a C6 for what is probably a much lower cost.
Yeah i was thinking c6, but i found this one for $150 so i didnt think i could pass it up. and i'll have to find a freshly wrecked ford van to get a tranny i trust as far as c6 goes
You could get an aod tranny b&m makes a good aod tranny i hear for good everyday use and you can also hotrod around with it vroom vroom !
Can someone fill usmc in on the best aod trannies for everydayuse and street use?
[/align]
The C4 is supposed to be capable of handling abuse, without spending two arms and a leg. As to exactly what to do, I'm not in the know. A shift kit, and sound bands and clutches at the very least. If you're really going to be serious about going fast, you should have a legitimate tranny shop advise you.
