Phenolic spacer question...
Old Apr 7, 2007 | 08:04 PM
Danas 65's Avatar
Danas 65
Default RE: Phenolic spacer question...
The coil is relatively new (replaced about 4 months ago when I installed Pertronix Ignitor and new wires). So, if it is the coil, it would have to be defective. How would I test it? My gut tells me it is something with the fuel b/c of the bubbling that I am seeing in the float bowl and in the clear filter. I am running pretty much the same setup as Soaring; so you would assume that I wouldn't have any problems. Soaring, do you have any pictures of your fuel line routing? We have had a turn of cooler weather here in Houston, the last couple of days and I haven't had any problems running it around. I am assuming that the cooler weather is helping the situation. Thanks for all the help guys. Any further input would certainly be appreciated.
Old Apr 8, 2007 | 03:12 PM
mikethebike's Avatar
mikethebike
ORIGINAL: Danas 65
When I rebuilt my XLCH 11 years ago I installed a NEW H-D coil and had the same type trouble you describe. Bought an Accel from Pete Hill, problem solved. But 185 fuel temp does sound a little extreme. I remember workiing on brother-in-laws 75 280-Z with K-Jetronic injection that had this in the service manual:
"this fuel system runs 37 psi, vapor-lock is NOT a problem."
PB Pod
Forum Issues and Feedback
Sep 17, 2015 08:32 PM
Webster454
Sep 7, 2015 04:59 AM
BigWave916
Wheels & Tires
Sep 2, 2015 08:26 AM
Wesley1995
Aug 30, 2015 02:01 PM
mtxplod
Aug 29, 2015 01:43 AM
