4 speed comversion
Old Apr 6, 2007 | 01:21 PM
robert912004's Avatar
robert912004
Default 4 speed comversion
Has anyone converted their mustang from a automatic to a manual, if so what all do i need for the swap?
Old Apr 6, 2007 | 01:31 PM
gothand's Avatar
gothand
Default RE: 4 speed comversion
I'm assuming you want a stock 4-speed with stock clutch linkage? Underneath, you'll need a tranny, bellhousing, clutch fork and pivot bracket, flywheel, pilot bearing clutch and pressure plate. Under the hood you'll need an equalizer bar (z-bar), engine block and frame rail pivot mount, nylon bushings and felt washers and upper and lower clutch lever rods. Under the dash you'll need manual pedals, pads and bushings, clutch pedal return spring, two spring bushings and a pedal stop.
I may be missing some things and using wrong names as I'm reciting this from memory. Your best bet is to look in a good catalog from NPD or the like and see what parts you'll need.
FWIW, unless you have some specific reasons to do so, I'd forget the 4-speed and put in a T-5. It is lighter, has better gearing and shifts a lot easier.
Old Apr 6, 2007 | 01:41 PM
NorCalTroy's Avatar
NorCalTroy
Here is a link about a T5 swap.
http://www.fordmuscle.com/archives/2000/09/t5swap/
Also, there are several exsisting threads about this topic, do a search and you will find a lot of information
https://mustangforums.com/search.asp
Good luck!
Old Apr 6, 2007 | 07:01 PM
tommus66's Avatar
tommus66
Here's a great article for a Ford falcon C4 to T5 swap similar chassis as the Mustang!-Tom
http://xanthe.lunarpages.com/~nkfalc...oration/T5.htm
Lethaldosage423
Oct 19, 2015 12:12 AM
UrS4
Oct 3, 2015 06:23 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
BeatnikFink
Oct 1, 2015 08:00 PM
musnicki
Sep 23, 2015 07:11 AM
