front end help
Old Apr 8, 2007 | 11:28 PM
lilrobo's Avatar
lilrobo
Default front end help
hey guys my son has a 65 coupe and the car gets real floaty 60 mph and up its has power steering ,, what do you think it might be ,, we did change the strut bushing could it be shocks,, steering gear box?? we have never adjusted it someone told us that its supposed to come back to middle after turning, his don't but that might be the old stile ???
Old Apr 9, 2007 | 01:10 AM
6mustang6's Avatar
6mustang6
Default RE: front end help
A improper alignment can cause the steering not to return. A steering box adjusted to tighty can also cause it. The floaty feeling is probably just worn out suspension, however check the steering box tightness.
Old Apr 9, 2007 | 02:23 AM
66GTKFB's Avatar
66GTKFB
The car is 42 years old. Rebuild the power steering control and the upper A arms. Replace everything else. You can probably keep the springs.
Jim
Old Apr 9, 2007 | 08:45 PM
lilrobo's Avatar
lilrobo
is there a check i can do on the steering box
Old Apr 9, 2007 | 08:54 PM
65mojoe's Avatar
65mojoe
+1 on the alignment...also, what kind of condition are the tires in? Your floating sounds like it could be a case of bump-steer, in which the tires tend to follow ruts and bumps in the road.
Old Apr 9, 2007 | 09:00 PM
lilrobo's Avatar
lilrobo
well the tires are in good shap likenew i say maybe 2 years old and we never seen any kind of wear,, as long as you keep it under 60 or so its fine its hard to say cause of power steering its easy to steer anyway,, but you get to 70 or higher man it tricky
Old Apr 9, 2007 | 09:08 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
if its not returning to center the idler is bad the play but theres probably a combo of the ps ram the tie rods and ball joints etc it would be wise to go ahead and get a master rebuild kit
Old Apr 10, 2007 | 07:42 AM
lilrobo's Avatar
lilrobo
what about cam and caster we have never looked or check it could that be the trouble we have checked the tie rods and ball joints
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
the5
Sep 19, 2015 06:13 PM
Sparks_88
Sep 8, 2015 01:06 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
