I need engine help!
Old Apr 11, 2007 | 11:07 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default I need engine help!
OK, so im now finishing my project, except theres on little problem my 302 wont turn all the way by hand, and im to scared to try and turn it over. i've got dirt in the #1 piston im thinking it might be a dirt dobber made a nest in there, but if thats not it what are some other possibilities?
Old Apr 11, 2007 | 11:10 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: I need engine help!
The piston has frozen to the wall?
Old Apr 11, 2007 | 11:11 PM
USMCrebel's Avatar
USMCrebel
no it'll go all the way down, but wont go all the way up....
Old Apr 11, 2007 | 11:30 PM
my77stang's Avatar
my77stang
sounds like its time to pop the heads off and see whats happening, hopefully it only costs you a head gasket set (cheap enough)
Old Apr 12, 2007 | 12:28 AM
USMCrebel's Avatar
USMCrebel
i was trying not to do that but looks like im going to have to.
Old Apr 12, 2007 | 02:01 AM
JMD's Avatar
JMD
Yea, if it wont turn,,, do not force it under any circumstances.
If you have not pulled the plugs yet, you might do so, if the engine has water or fluid down a cylinder, it will not turn against compression.
Old Apr 12, 2007 | 02:09 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
+1 on the rlight rust id pour marvel mystery oil in all the cylinders let it sit for a week or so then try turning it over
Old Apr 12, 2007 | 03:20 PM
USMCrebel's Avatar
USMCrebel
OK, i looked at it again and it looks like a dirt dobber built a nest in the #1 cylinder, could that be whats stopping it...there is oil in the motor, but it should turn all the way over shouldnt it?
Old Apr 12, 2007 | 03:27 PM
my77stang's Avatar
my77stang
your gonna have to pull that one head to get him outta there
Old Apr 12, 2007 | 03:36 PM
USMCrebel's Avatar
USMCrebel
can i do it form the exhaust manifold holes?
