Electric Fan Q?
Old Apr 12, 2007 | 04:41 PM
BeastMachine69's Avatar
BeastMachine69
Default Electric Fan Q?
Hey guys, so I was looking into installing an electric fan on my 69 but, I was told it could be used as a puller or a pusher....what the hell does that mean?? lol how do I know which way to install it?
Old Apr 12, 2007 | 04:53 PM
JMD's Avatar
JMD
Default RE: Electric Fan Q?
Puller = behind raddiator
Pusher = in front of radiator
I have my doubts that there is enough room in front of the radiator on a Mustang, but there might be, someone here will know!
Old Apr 12, 2007 | 05:35 PM
Soaring's Avatar
Soaring
I ♥ Acer
If you don't have an air conditioner you could put a pusher in front of the radiator, but Why do that? I had remembered that a pusher is not as efficient as a puller but I didn't remember by how much, so I researched and found this statement from a radiator fan company.
"A puller fan is more efficient. A pusher fan is generally only 80% as efficient as a puller fan."
Old Apr 12, 2007 | 05:49 PM
BeastMachine69
well if I put it in the front should I still use my regular mechanican fan?
Old Apr 12, 2007 | 05:54 PM
sxs191's Avatar
sxs191
If your not having overheating issues I'd just use the electric fan as a puller. That way you can take off the mechanical fan and add an extra HP or two.
Old Apr 12, 2007 | 05:57 PM
JMD's Avatar
JMD
ORIGINAL: Soaring
These figures are the same asI remember as well.
Old Apr 12, 2007 | 06:03 PM
JMD's Avatar
JMD
ORIGINAL: sxs191
I have heard that stock non-clutch fans can consume as much as 15 HP, with at least 7 HP being typical, even for "flex fans".
If going to an electric, I would ditch the mechanical fan as well.
Most aftermarket electrical fans come with a cheesy thermostat "sensor" that goes through the radiator core, I dont like this much, I have always put a sensor into the thermostat housing and used a relay to swithch the fan on and off. This makes for a cleaner, more reliable,and more professional install.
Old Apr 12, 2007 | 06:29 PM
BeastMachine69
so just to be clear a puller is behind the radiator such as inside the engine bay right? not in the front near the grill?
Old Apr 12, 2007 | 06:49 PM
NorCalTroy's Avatar
NorCalTroy
ORIGINAL: BeastMachine69
Yep that's correct, a "puller" pulls the air through the radiator into the engine compartment and a "pusher" pushes the air through the radiator, into the engine compartment.
Old Apr 12, 2007 | 07:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
If you want to save a few coins, consider going to the junk yard and robbing one off another car. Here is a good article about which cars to rob.
http://www.fordmuscle.com/archives/2...cfan/index.php
