9" Rear
Old Apr 12, 2007 | 06:05 PM
601HP's Avatar
601HP
Default 9" Rear
Hey folks!!
I have a 1966 Mustang with a 9" Traction-Lok. I would like to do my own ring and pinion swap. What technical source do you recommend for me to refer to?
I have dial gauges, calipers, floor press, air power, etc. I just need good written guidance and also a source for shim packs, crush collars and such.
Thanks a bunch.
David
Old Apr 12, 2007 | 06:31 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: 9" Rear
Normally, I would advise to take the rear to a pro and have them do it because it can be screwed up real easy. However, you sound like you might know what you are doing. Here is a fairly good tech article about how to do it. Good Luck!
http://www.drivetrain.com/ringpinioninstal.html
Old Apr 13, 2007 | 06:18 PM
601HP's Avatar
601HP
Default RE: 9" Rear
Soaring,
Thank you very much. I'm always open to a new challenge, so with the proper parts, information and tools, why not try to increase my mechanical skills? At age 54, why quit now?
David
Old Apr 13, 2007 | 06:29 PM
gothand's Avatar
gothand
Default RE: 9" Rear
Take a look in the factory service manual which gives a pretty good writeup on this IIRC. From what I've seen, setting up a removablecenter sectionlike the Ford 9" is a bit different than say a Dana axle.
Old Apr 13, 2007 | 06:36 PM
350kmileFord's Avatar
350kmileFord
Default RE: 9" Rear
It's supposed to be easier, the 'frontloading' type (9")
Old Apr 13, 2007 | 07:22 PM
DonA's Avatar
DonA
Default RE: 9" Rear
As someone who has taught this proceedure about a hundred times I can gurantee that you will not do it correctly even with the best written instructions.
You must first understan exactly what you are trying to accomplish.
On the other hand once you do understand that you can set up any rear car or truck
The end result of what you are trying to do is to extablish a proper contact between ring and pinion teat and to make sure that it will NOT varie even the slightest bit even under full engine torque multiplied many times by the convertor plus the transmission plus the rear
There are four esential adjustments
1. Pinion Depth
2 Pinion bearing preload (The most mis-understood)
3 Ring and pinion back lash
4. Differential Bearing Preload
Old Apr 13, 2007 | 08:10 PM
66GTKFB's Avatar
66GTKFB
Default RE: 9" Rear
Right-on.
Jim
Old Apr 15, 2007 | 05:31 PM
mikethebike's Avatar
mikethebike
Default RE: 9" Rear
ORIGINAL: DonA
1. Pinion Depth
And if he has REAL power he might want to consider a 'load bolt' that is nothing more than a bronze tipped bolt mounted in the housing that is adjusted so should the ring gear attempt to back-up more than around 1/100" it will contact the bolt and STOP. All the pro-drag racers back in the 60'70's used them. Worked grreat. CHEAP!!!!!!!
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Sep 30, 2015 10:13 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
