'66 Ranchero 9"?-post 12
I am emailing a guy who is selling a 9" w/ 4.11 on Craigslist... He also wants me to buy his 351 w/ 40k miles along with it for 800 bucks as a combo deal-not a bad deal at allbut I just do not need the engine. Anyway. He says that the width from drum to drum is 59". So this must mean that the flange to flange width is either 52 1/4" or 52 3/4", right? Does anyone know for sure if this axle will or will not work? I searched through pages of results on Google but couldn't get a definate answer.
I did email him back...
Are you sure that the axle for the 65-66 is 57.25"
I have seen in many places that it is 52 1/4"
http://www.ultrastang.com/Rearinfo.asp?Page_ID=1
Wow, I just realized that I've been making a mistake while looking for rearends >_<
After reading that page I kept thinking that 52 1/4" was measured from flange to flange, not housing end-end
Yeah, you always want the flange to flange length. Here, print this out and take it to a junkyard.
http://www.mustangsandmore.com/ubb/F...imensions.html
The axle flange is where your lug nuts are stuck into a round thing, Maybe this pic will help. Just scroll down a couple of clicks to see the pic of where the flange is on your axle. http://www.jegs.com/customerservice/CustomAxleForm.pdf
if i hadnt just taken a bath id go out and check my f150 its an 86 so samething but im all spic and span but i believe they used the 8.8s but i could be wrong?
I know what the flange is >_<
According to one site, the 84 Bronco did have a 9 " Weren't the offset differentials only in the front though?
I was asking if the outside drum-outside drum distance was basically the flange distance because the flange meets right at the brake drum:
So it's basically 59" - 1/8"x2 for the drum material. Correct?
