valve covers
Old Apr 18, 2007 | 12:13 PM
jp51mustang's Avatar
jp51mustang
Default valve covers
Should I buy tall or short valve covers? I've installed roller tip rockers and a new cam but other than that my valve train is stock. Is there a benefit to one or the other? Clerance issues? It's a 65 289, and I've got an Edelbrock intake manifold and may one day want AC. Thoughts?
Old Apr 18, 2007 | 02:46 PM
66GTKFB's Avatar
66GTKFB
Default RE: valve covers
Original Mustang V8's thru 67 (and 68 289) all used the lower profile valve covers. In 68 Ford went to the tall on the 302. You should get the tall type in cast aluminum for your engine. There are manytypes with different cast in names.
Jim
Old Apr 18, 2007 | 03:12 PM
jp51mustang
If I'm reading your reply correctly... Being a 65 the lower type will fit, right?
Old Apr 18, 2007 | 05:07 PM
66GTKFB's Avatar
66GTKFB
The two styles will fit the heads for all 260 and 289engines, the low/short may not fit a head with taller valve springs or other mods.
Jim
Old Apr 18, 2007 | 05:56 PM
gjz30075's Avatar
gjz30075
It'll be a tight fit.The baffles will be the problem. You may have to drill some holes in them where they contact the rocker.
Old Apr 18, 2007 | 06:39 PM
my77stang's Avatar
my77stang
might as well go tall and not worry about clearance issues
Old Apr 18, 2007 | 07:55 PM
mikethebike's Avatar
mikethebike
ORIGINAL: jp51mustang
Bite the bullit and buy hollow letter Cobra covers. Set the covers finger tight with gasket in place and mark the interference with dye on the rockers. Then heat the baffle and dimple it with a ball-peen hammer. You're done, nobody knows you have roller-rockers and your engine looks right. (I hate tall valve covers)
Old Apr 18, 2007 | 08:41 PM
my77stang's Avatar
my77stang
i quintuple stacked valve cover gaskets to retain the black wrinkle finish ford motorsports covers
Old Apr 18, 2007 | 10:17 PM
baddog671's Avatar
baddog671
They also make cover spacers, or you can double gasket it if you want to jimmy it for now
Best bet to just buy the tall ones though..
Old Apr 19, 2007 | 12:20 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Tall covers. You'll wind up going full roller later on...
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
winner99
Oct 1, 2015 01:06 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
