Battery Replacement
Old Apr 18, 2007 | 02:28 PM
jspagna1's Avatar
jspagna1
Default Battery Replacement
Does anyone know if they make batteries that will fit a 1966 Mustang that has the lip on the sides so that they can be clamped down like the original set up or do you need to change the battery tray to a '67-'68? TIA
Old Apr 18, 2007 | 02:51 PM
66GTKFB's Avatar
66GTKFB
Default RE: Battery Replacement
There is a bracket that goes under a 65-66 tray that allows you to use the 67 on, hook screws, top clamp and wing nuts if you can't find a 'eared' type battery.
Jim
Old Apr 18, 2007 | 03:23 PM
jspagna1's Avatar
jspagna1
Jim, would really solve my problem. Do you have the supplier or part's or any information? I would greatly appreciate it.
Joe
Old Apr 18, 2007 | 04:47 PM
Soaring's Avatar
Soaring
I ♥ Acer
CJ Pony carries the original 24F Autolite batteries with the lip on the bottom.
Old Apr 18, 2007 | 05:03 PM
66GTKFB's Avatar
66GTKFB
National Parts Depot has the bracket p/n 10769-2A $9.95; a hold down kit p/n 10756-1K $2.95 and the clamp p/n 10718-2A $4.95. Repro Autolite batteries are over $130. You may check out your local auto store to see if they have an 'eared' type 24F battery. I've seen them but opted for a more positive tie down.
JIm
Old Apr 18, 2007 | 05:48 PM
jspagna1's Avatar
jspagna1
ORIGINAL: 66GTKFB
JIm
That is great. Thanks a lot for part#'s
Old Apr 18, 2007 | 07:55 PM
JamesW's Avatar
JamesW
Another solution is to mount a 69 style battery tray and turn it sideways. It's a cheap fix and works well.
http://www.midnightdsigns.com/Mustan...r_install.html
Old Apr 18, 2007 | 08:15 PM
Soaring's Avatar
Soaring
I ♥ Acer
My Interstate Mega-Tron Plus battery fits the tray just fine, and it also has a small lip around the bottom where I am able to attach the original hold down so that the battery is secure. There are about 500 different ways to skin a cat, and probably more ways to keep a battery in its' place to include bunji straps.
[IMG]local://upfiles/10034/48AF480908854E699747C019E6D344D5.jpg[/IMG]
Old Apr 18, 2007 | 09:01 PM
19stang66's Avatar
19stang66
+1 for Bungee cords!
Old Apr 18, 2007 | 09:04 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 19stang66
Is that how you spell that word?
