Typical Tune-Up
Old Apr 23, 2007 | 02:39 PM
boogerschnot's Avatar
boogerschnot
Default Typical Tune-Up
Since I bought my 69 I have changed the oil, coolant (radiator too),pwr steering fluid, and tranny fluid, and I have ran a bottle of fuel system cleaner.. I have checked the plugs,, they look good and the car runs good, so what else should I be looking at as for as a tune up is concerned? I have adjusted the curb idle to where I think it should be (probably a little high) but how about fuel mixture? Timing? How hard is it to advance timing? and should I?
http://new.photos.yahoo.com/otaiko7/...804282482599/0
Old Apr 23, 2007 | 03:09 PM
NorCalTroy's Avatar
NorCalTroy
Default RE: Typical Tune-Up
Fluids (oil, coolant, power steering, tranny)
Filters (oil, air, fuel, tranny)
PCV valve
Distributor cap, rotor, wires & plugs
Points (if you still have them)
Vacuum lines
Belts
Timing
Carb tune (idle & air/fuel mixture)
Rear differential fluid
Lube chassis
Lube door/trunk/hood hinges and latches
Battery/charging system
Brake pads/shoes & fluid
Tire pressure/tread
Check all lights
Wash, polish & wax
Old Apr 23, 2007 | 03:17 PM
boogerschnot
Forgot a few things thatI did do..
-Rear end oil change
-The cap and rotor/points are all new looking on the inside..
-New tires on front end, rear are good, just a crappy size 205 70 15,, front 225 60 15 BF geforce
-New alternator/ voltage regulator / battery
Need to lube the chassis though..
Pads and shoes are great but I do need to change the fluid..
Anything else? I think Im pretty much on top of this thing.. I did notice today that on my front right fender where it meets the light housing it is bondo'd to the housing I dont know why though.. I think the car was wrecked on the front end and then fixed and now the bondo is cracked .. That sucks..
Old Apr 23, 2007 | 03:28 PM
NorCalTroy's Avatar
NorCalTroy
I can't think of any thing else right now, but maybe other people can pitch in. I'll add everything to my list and maybe we can get a sticky or an entry into the FAQ section. I'll also edit my post to include the items that you mentioned in your original post.
mtgldr
Feb 3, 2024 09:00 PM
KingRando
Oct 2, 2015 08:06 AM
guitarman376
Sep 30, 2015 05:54 PM
tmdm
Sep 4, 2015 06:45 PM
ccwebb
Aug 11, 2015 06:47 PM
