Hard Brake Decision
The first thing I did to my 67 was brakes. Stop fast before go fast. I bought a set of American Wheel(iirc) 15" $25/pc cheapo steel wheels because the 14" won't fit. I ran the Wilwood disc conversion kit that can be had in Summit's catalog for around $615. The kit is a complete bolt up to a factory front drum assembly(at least for the 67) with drilling required if you're converting factory disc to Wilwood's. You'd also need a master cylinder(decent Wilwood dualfor around $100-120$ iirc) and a proportioning valve to control F/R brake bias, and then some flexible brake lines and fittings to fit the caliper/factory hardline etc. I like the Wilwood's because that kit is functional, not visual, they WORK. Wilwood also offers a whole line of pad compounds, from mild street quiet stuff to steel vaporizing superspeedway 200+mphheavy carcompounds(not for street). You can also pick up replacement rotors(11.75"x0.810" vented steel alloy) for around $25-30 a peice new retail. I still run factory drums, but with good tires the beast stops VERY quickly. I've had the same discs with somewhat abrasive pads for around 2 years now I think. somewhere between 50k-80k miles on them and they're just getting to the point of needing to be replaced, and I use my brakes like they're free.
+1 with Glen on this one. http://www.discbrakeswap.com/is a good deal for $550. Junkyard Granadas are over $200 and then you still have to buy new calipers, rotors, components..etc...
Plus, the new spindles from Dennis correct thepast Granada geometry issues.
ORIGINAL: PReal
I'm going to try to barter my outlaw 14's in great condition for some 15 steel wheels or mags in poor shape.
but i want a pic of your car with those outlaws on first[>:]
if you want to keep your 14s https://mustangforums.com/m_3055115/tm.htm and https://mustangforums.com/m_3052549/tm.htm
ORIGINAL: atomsk680
if that doesnt work, pay it forward
ORIGINAL: PReal
If you can live with GM calipers you could check with Scarebird to see if his set up works with 14" wheels.
http://www.scarebird.com/12802/19004.html
Here is an install write up by a happy customer
http://www.cardomain.com/ride/358218/3
I'm researching my options and this is one I would consider, but I have 15" TT-IID so I haven't researched the 14" wheel issue. If you're going to change wheels, I would consider 17" wheels from a modern mustang that will allow use of 13" cobra disks ala MustangSteve.
What worries me about that is the guy has ebay feedback of 100% for 3200+ transaction he must have annoyed somebody by now!! I might be just being paranoid and he may be a great guy but that my mentality!!! hopefully some more knowledgeable person can answer because I think if it is that easy to do why is everybody like cj pony part not carrying the same type of kit?
