pertronix ignition system
hi lads. i lookin for help wil a pertronix ignition system fit my straight 6 coupe. wil it improve spark plug life and improve fuel econonmy and performance.. i know nothing about this to be honest but it was recommend from a friend to get it. any help would be great thanks
The main advantage is the lack of maintenance needed with the pertronix it may improve spark plug life and fuel economy but nothing magical, depends on how well maintained and set your points are.
The main improvement is that you won't have to maintain the timing and the points. This could result in longer spark plug life and better power, but only compared to acr that is not properly timed or has worn points. So, if you enjoy setting the timing every 1,000 miles or two months and performing routine maintenance including replacing points, the Pertronix kit is even a disadvantage because it takes the joy of this maintenance away from you
bradleyb
Nov 27, 2015 07:50 PM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
