How much horsepower?
Old Apr 28, 2007 | 03:44 AM
papi_chulo's Avatar
papi_chulo
Default How much horsepower?
How much horse power is in a stock 68 302 and how much can i get from it? my budget is 4000 trying to spend a lil lower
Old Apr 28, 2007 | 03:46 AM
atomsk680's Avatar
atomsk680
Default RE: How much horsepower?
a stock f code 302 has 210 HP
they can obtain quite a bit it just depends on how much you WANT to spend and what you want to get
Old Apr 28, 2007 | 03:51 AM
silverblue66's Avatar
silverblue66
yeah, around 210. you can get up to 540-500 horsepower from a 302 if you are willing to spend $$$$. for around 4k you can probibly build a healthy 350-375 hp 302. check out coast high performance and Perfoamance automotive wharehouse (PAW), they both offer good engine kits PAW is a little cheaper. also a pare of AFR or TrickFlow heads will do wonders. don't let AFR's prices get you down, invest in a few good parts and you will be happy in the long tem. I am building a 302 with AFR 185s fors about $4500 and it should put out 420 hp. Hopefully.
Old Apr 28, 2007 | 03:52 AM
silverblue66
this is a little off topic. does has anybody gotten 400 horsepower from thier 289? and was it streetable?
Old Apr 28, 2007 | 04:10 AM
gothand's Avatar
gothand
... as the dyno tuner responded to me when I asked a similar question, he said, "define streetable". As it turns out, mine is built for peak horsepower at the expense of low end torque, thereby not very streetable by my standards. [] FWIW, my 302 is advertised as 375 hp.
Old Apr 28, 2007 | 05:13 AM
superdavid's Avatar
superdavid
Is $4000 your total budget, or just your motor budget? Anything over 300 hp and the rest of your drivetrain is going to start coming apart.
Old Apr 28, 2007 | 12:11 PM
papi_chulo's Avatar
papi_chulo
This is my total budget maybe pushing to 5000.
Old Apr 28, 2007 | 12:16 PM
JamesW's Avatar
JamesW
What kind of shape is the rest of the car in? That 4K may be better spend on brakes & steering before installing a beast motor....
Old Apr 28, 2007 | 12:37 PM
papi_chulo's Avatar
papi_chulo
Im going to be fixing the steering also and it has brake drums. the rest of the car is in good condition
Old Apr 28, 2007 | 01:00 PM
68SCode4speed's Avatar
68SCode4speed
I've posted this link before for others to read - it is a very easy way to make more power without breaking the bank and yet keeping it streetable. Obviously you don't have a roller cam but you can install one that is specifically made for a non-roller block like yours. Good luck. +1 on what James said about the brakes & steeringthough...
http://www.carcraft.com/techarticles...ngine_buildup/
