Monte Carlo Bar & Air Conditioner?
Old Apr 30, 2007 | 11:53 PM
colostang's Avatar
colostang
Default RE: Monte Carlo Bar & Air Conditioner?
I don't know why, but that curved MC bar would not fit with my AC with the 289. Maybe there are different manufacturers of these things with different bends but I left the one I bought off because it hit the compressor. I looked and looked but couldn't figure a way to get everything to squeeze in. One of the fun things about these cars...what should work, doesn't always.
Old May 1, 2007 | 10:47 AM
mikethebike's Avatar
mikethebike
Why not go to a late model radial compressor?
Old May 1, 2007 | 03:12 PM
marekra's Avatar
marekra
Place the bar behind the dist. this will require shorting the bar. measure and cut difference from the center of the bar and reweld. this is what i did. it also dows a better job due to using compression on the bar vs shear on the mount bolts for shock tower flex. see my gallery for example on how i did the end mounts.
bob
[align=left] [/align]
Old May 1, 2007 | 05:01 PM
JMD's Avatar
JMD
I want to thank everyone for their help and input! I will have some time to resolve this issue, so I will consider all input!!
Old May 2, 2007 | 01:43 PM
rsk289's Avatar
rsk289
Whoa - don't spend money on a Sanden until you can try it. I am installing a Classic Auto Air system, which uses a Sanden, and I have exactly the same problem. The brackets hold the Sanden fairly high up, and the back of it contacts the curve of the bar long before it lines up with the holes. (351 - well, 392 stroker - in a '68).
The only answer I can see is to weld up or somehow fabricate a bar myself, which will never look as good as the shop-made device. This is a pain, as I'd had the bar powdercoated to suit the rest of the underbonnet, and now can't use it!
Have you found an answer yet?
Roger
Lethaldosage423
Oct 19, 2015 12:12 AM
flash_xx
Oct 16, 2015 07:23 AM
fastbackford351
Oct 1, 2015 12:24 PM
winner99
Oct 1, 2015 10:52 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
