heater plenum re/re
Old Apr 29, 2007 | 08:20 PM
66 girl's Avatar
66 girl
Default heater plenum re/re
it is finally time to replace the original cardboard heater plenum. i have a shiney new brown plastic one,,, but seems to me that there should be something (a gasket? short connecting tube?) that goes between the square end and the same size opening by the fire wall.
thanks!
Old Apr 29, 2007 | 08:22 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: heater plenum re/re
What year mustang do you have, and do you have air conditioning?
Old Apr 29, 2007 | 08:26 PM
JamesW's Avatar
JamesW
Only photo I have of a defroster plenum. It attaches to the back/side of the fiberglas heater box.
Old Apr 29, 2007 | 08:55 PM
66 girl's Avatar
66 girl
it's a 66 no air conditioning....
great photo JamesW! - mine looks identical, but there's about 4 inches space, where yours lines up nicely. will have to check carpet, etc. getting in the way of it lining up correctly.
Old Apr 29, 2007 | 09:06 PM
66GTKFB's Avatar
66GTKFB
I bet it's the defroster deflector, that's the only cardboard item on the heater.
Jim
Old Apr 29, 2007 | 09:11 PM
JamesW's Avatar
JamesW
it should slide up. Make sure all your old cardboard is gone. It should mount with small sheetmetal screws.
Old Apr 29, 2007 | 09:18 PM
66GTKFB's Avatar
66GTKFB
Correct, 2 on the inside and 2 on the outside. Ford p/n 42119-S2, 8-18x3/8 hex head with a small flange, phosphated , not zinc plated. Jim
Old Apr 30, 2007 | 01:06 AM
ndnboy's Avatar
ndnboy
just replaced mine a couple of weeks ago, it was a tight fit but it finally slid onto the receiving end and srcewed it down, be patient and good luck : )
Old Apr 30, 2007 | 03:47 PM
Charlie1's Avatar
Charlie1
I pulled the carpeting down out of the way and that made the alignment issue much easier.Since the friction fit was pretty good, Iwent with two screws...just too hard to get at the back ones. Maybe this year I'll try again with different tools.
djbigskrilla
Sep 20, 2022 01:04 AM
mrtrodonet
Sep 19, 2020 03:12 PM
Seanam
Oct 4, 2015 10:15 AM
GimpyHSHS
Sep 18, 2015 12:27 PM
Gary Ugarek
Aug 26, 2015 08:41 AM
