Engine Help-many questions
Old May 2, 2007 | 05:41 PM
66GTKFB's Avatar
66GTKFB
Default RE: Engine Help-many questions
From 66 on, all Ford factory production engine's were painted blue. There are exceptions.That engine in the convertible looks like it's froma 68 or later.
Jim
Old May 2, 2007 | 07:21 PM
chrisal's Avatar
chrisal
oops, i have been corrected by the owner and the car is actually a 1966 and not a 1965. So, i guess the blue all over is correct-isnt it??
Old May 2, 2007 | 07:30 PM
66GTKFB's Avatar
66GTKFB
Ford spray can blue to be accurate. They call it 'Corporate Dark Blue'.
Jim
Old May 2, 2007 | 07:46 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 66GTKFB
Jim
It's also called Ford Blue. 1965 was the only year for the gold and black. Just to hammer it home......there are no numbers matching 1965 or 1966 Mustangs. Don't even try to find out where the parts came from because even Kevin Marti will not be able to tell you. Just put whatever engine you want in there.
Old May 2, 2007 | 08:27 PM
66GTKFB's Avatar
66GTKFB
Glen, don't forget the 64 260 valve covers, they were 'Medium Blue'. And as to matching numbers, I had a 66 with a T-10 transmission and it had the VIN number on it, well it was a San Jose Fastback build with a Metuchin hardtop VIN on the T-10.
Jim
Old May 2, 2007 | 08:36 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 66GTKFB
Jim
Obviously not a numbers matching car. Part was built in San Jose, and part was built in Metuchin?
Old May 2, 2007 | 08:50 PM
66GTKFB's Avatar
66GTKFB
An anomous previous owner blew the original transmission and replaced it. That's the story I got from the guy I bought it from. Don't know the realwho, where or when, but it's academic because the car now speaks Austrailian. But it did have the VIN on it. It will be documented in the next issue (if Smart and Haskell get around to it) of the Mustang Production Guide.
Jim
Old May 2, 2007 | 09:06 PM
chrisal's Avatar
chrisal
I've been looking at the picture of the engine and then comparing it to a book i have. It looks like the air cleaner and valve covers are off a 68 302. What do you all think. they, the valve covers,have the large powered by ford script on them
Old May 2, 2007 | 09:29 PM
66GTKFB's Avatar
66GTKFB
Way back in this thread I said it looked like a 68 - the air cleaner and preheat tube, distributor and - yup, the valve covers. It could be a 289 because Ford 'used' up all the leftover 289 blocks as 68 2V ('C' code) engines.
Jim
Old May 2, 2007 | 11:32 PM
chrisal's Avatar
chrisal
I wasnt trying to discredit you, actually, i new to compare those photos because of you-thanks!
GimpyHSHS
Aug 29, 2015 06:30 PM
classic69FB
Aug 12, 2015 11:58 PM
$A_Money$81
Aug 11, 2015 01:30 PM
HIS S-197
Aug 10, 2015 05:47 PM
