Lean best idle??
Old May 4, 2007 | 12:28 PM
mat11089's Avatar
mat11089
Default Lean best idle??
I have a stock late model 302 with c4 trans and a holley 4160 4bbl in a 66.I puta vacuum gauge to it to check for lean best idle.What kind of reading should i get and which vacuum port to use.I used the one on the bottom plate in the front.I got something like 20-21.
Old May 4, 2007 | 01:57 PM
NorCalTroy's Avatar
NorCalTroy
Default RE: Lean best idle??
You can use any manifold vacuum port to measure vacuum. If you hook your gauge up to a timed vacuum port, it probably won't (shouldn't) register much of a reading at idle, so you will know that you have the wrong port.
20-21 inches of steady vacuum is a good measurement, usually the higher the better. If it is below 16, or if it drops, or if it fluctuates too much, you know you have a problem. Yours sounds good though.
Old May 4, 2007 | 05:33 PM
woodywrkng's Avatar
woodywrkng
Put the car in drive, with the wheels chocked of course, and adjust your carb. The 20-21 inches is great, but I'll bet it's in neutral. Chances are you're using the correct vacuum port if you get this reading. What you want is manifold vacuum, like NorCalTroy sez.
Old May 4, 2007 | 06:44 PM
mat11089's Avatar
mat11089
Awesome thanks guys.
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
Dathan
Oct 5, 2015 05:52 AM
MacSerio
Sep 27, 2015 01:05 PM
