Putting headers on, Starter is in way!
Old May 4, 2007 | 06:34 PM
Frankus's Avatar
Frankus
Default Putting headers on, Starter is in way!
Is there a special starter I have to get to make my 302 headers fit? Theyre hugging the starter at the moment in a dangerous way...
Old May 4, 2007 | 06:42 PM
mat11089's Avatar
mat11089
Default RE: Putting headers on, Starter is in way!
I used long hedman longtubes on my 302 with a stock starter.Had to put starter in after but havent had any problems.
Old May 4, 2007 | 06:51 PM
66GTKFB's Avatar
66GTKFB
When you get done, look on the bright side - you have something to catch the starter in case it comes loose.
JIm
Old May 4, 2007 | 06:52 PM
gothand's Avatar
gothand
If it doesn't fit and you like the headers, get a mini starter that can be clocked.
Old May 4, 2007 | 09:25 PM
67mustang302's Avatar
67mustang302
I got a smaller starter for a late model stang, and ran the cable down like normal to the starter, then ran a jumper wire across to the starter(late model) selenoid from where the fender selenoid cable connects to the starter power source(late model starters have 2 terminals, one for power, then one for the selenoid on the starter to receive signal from the switch, so the wire is jumped from one terminal to the other on the starter). Otherwise, you'll have a fight on your hands trying to change starters. Worked for a long time so far, and man, it's a lot lighter too!!!
Old May 4, 2007 | 11:13 PM
Smothers's Avatar
Smothers
ORIGINAL: mat11089
+1
Old May 4, 2007 | 11:15 PM
Smothers's Avatar
Smothers
ORIGINAL: 67mustang302
Someone else just posted a pick of a much smaller aftermarket starter in another thread. D&mn if I can remember which thread...[&:]
Old May 4, 2007 | 11:25 PM
67mustang302
The aftermarket ones are pretty pricey, but better, so I just went with a stock late model 5.0 standard unit, not a high torque one
Old May 4, 2007 | 11:28 PM
grruminator78's Avatar
grruminator78
could always get some shorties! do you have power steering?
Old May 5, 2007 | 12:00 AM
67mustang302
Power steering is for sissies!!
