so i'm replacing the water pump
Old May 4, 2007 | 06:45 PM
grruminator78's Avatar
grruminator78
Default so i'm replacing the water pump
.....Any tips/reminders before I get started??
Old May 4, 2007 | 06:46 PM
gothand's Avatar
gothand
Default RE: so i'm replacing the water pump
Buy a quality one and not a cheaply reman unit. Nothing will ruin your day like the pump spitting the shaft into your radiator. BTDT ... twice! [:@]
[edit] Be careful not to overtighten (strip) or cross-thread the bolts into the soft timing cover. Starting with a new set of bolts is nice, especially if yours are old and crusty.
Old May 4, 2007 | 06:48 PM
66GTKFB's Avatar
66GTKFB
Replace all the bolts with new ones, at least grade 5.
If you strip one of the tapped threads in the timing cover do you have an insert kit or can get one.
Jim
Old May 4, 2007 | 11:13 PM
grruminator78
okay so new bolts.... where can I get em?
Old May 4, 2007 | 11:22 PM
4reboy's Avatar
4reboy
Don't use stainless bolts unless they are like hardcore super strong ones, or else they'll break off in the block. trust me i know.... [:@]
Old May 4, 2007 | 11:24 PM
grruminator78
will any bolts that match work?? or do I need special water pump bolts?
grruminator78
oh yeah and I've heard that some hose has a spring in it that keeps it from colapsing in on itself under high pressure. What is it called and where is it located and where can I get one?
Old May 5, 2007 | 01:46 AM
gothand's Avatar
gothand
ORIGINAL: grruminator78
If you have a really good hardware store, bring your old ones and match them up. Otherwise, you can get a set of timing cover/water pump bolts for about $23 from Summit or maybe your local speed shop.
http://store.summitracing.com/partde...p;autoview=sku
Old May 5, 2007 | 11:19 PM
grruminator78
cool thanks! I'll remember that!
Old May 5, 2007 | 11:23 PM
JamesW's Avatar
JamesW
Get a piece of cardboard and trace the outline of the new waterpump on it. Use a pencil to poke holes where the bolts go. Remove them in order off your motor and put them in the corresponding hole in the cardboard template.
They are various lengths and otherwise you'll not remember where they go.
