Drum Tweaking
Old Dec 13, 2004 | 10:45 PM
ivanr77's Avatar
ivanr77
Default Drum Tweaking
Gonna make this a short post...not gonna get into the whole explaining deal.
But i'm having trouble with my brakes, My FrontLeft pulls first when i brake, but once i brake harder, my car begins to veer right. I dont understand how the car veers left than Right. I had a problem with the car veering to the right a month ago, but i fixed that by replacing the rear cylinder on the left side which was busted...causing the left to function at 50%...now that i've fixed the rear cylinder, the brakes should be braking equally...but they are not. I've tweaked the distance of the shoes for 2 weeks now trying to align the shoes in the correct position so that the brakes brake equally...but i cannot get it done. It seems the more that i try to fix it, the more awkward the brakes get. Any ideas on how to measure how much i should adjust the shoe distance from the drum?
Old Dec 14, 2004 | 01:06 PM
horseshoeing's Avatar
horseshoeing
Default RE: Drum Tweaking
Get disk brakes
When you back-up, Don't the adj. themself?
Old Dec 14, 2004 | 02:36 PM
69mach1377's Avatar
69mach1377
Spin the wheels and listen for rubbing and how quickly they slow down. Adjust the star until they match.
Front disks are highly recomended and much safer.
Old Dec 14, 2004 | 05:44 PM
me alot fast than u's Avatar
me alot fast than u
I ♥ Acer
I would say replace the brake lines as the rubber part might be collapsing
Old Dec 14, 2004 | 07:02 PM
ivanr77's Avatar
ivanr77
pfttt.id love to get disc brakes but they come at a nice price tag. One which i cannot afford....so therefore im reducded to fiddling with my drum brakes.
@Horse--i dont think mine automatically adjust, ive read about them supposedly adjusting automatically, but as far as i know mine dont.
@69mach--could you explain that in a bit more detail? I dont quite get what youre talking about in some things, such as "listen for rubbing and how quickly they slow down" are you referring to how quickly the brakes slow down or how quickly the rubbing noise comes in?
Old Dec 14, 2004 | 07:21 PM
69mach1377's Avatar
69mach1377
With both tires up off the ground, spin the tires equally and time them to full stop. Also listen to the shoes rubbing on the drums.
Remove the rubber plug from the oval hole to access the adjustment 'star' or gear shaped thing. Rotate them one way or the other until both tires have equal slowing resistance. Pump the brakes a couple of time and see if things change.
Repeat again, but if they cannot be equalized, then something probably needs replacing...like a wheel cylinder or brake hardware or ???
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Oct 7, 2015 07:02 PM
DCole24
Sep 11, 2015 10:50 AM
Tyoung68
Aug 25, 2015 04:31 AM
