Transmission Q's
Old May 7, 2007 | 01:12 PM
PReal's Avatar
PReal
Default Transmission Q's
Guys,
I think I am having tranny problems.
I have a 65 289 with a 3 speed C4. The car usually goes in gear very easily, but sometimes it seems to lose its gear when I stop. (It feels like I shifted to neutral) If I rev it a little and wait it usually kicks right back into gear. The fluid level is a little high and the fluid is really nasty brown.
I'm thinking of doing a fluid and filter change as well as adding some lucas transmission fix. Is there a possiblity my bands are loose or is my tranny more then likely shot.
Thanks,
Parker
Old May 7, 2007 | 01:43 PM
19stang66's Avatar
19stang66
Default RE: Transmission Q's
Yea you definitly need to change the filter and fluid. And make sure to use Type F (not 100% sure, i forgot) Automatic Transmission Fluid, that's what these old trannys have to use.
Old May 7, 2007 | 01:54 PM
PReal's Avatar
PReal
ORIGINAL: 19stang66
I did the filter and fluid once already (used type f fluid as recommended) and I honestly think I need to do it again. I'm even thinking of getting a couple gallons of type f togther and trying to flush the system using the tranny cooler lines.
Old May 7, 2007 | 01:56 PM
dr1965's Avatar
dr1965
I would do the fluid change a.s.a.p.
speaking of that trans. I have an issue where the shifter seems off,When i put it into reverse, the indicator is in the N, How can i adjust it so that it is on the R for reverse,N for nuetral, and so on.
Old May 7, 2007 | 01:59 PM
66GTKFB's Avatar
66GTKFB
Does the T handle wobble from side to side? If so, you may need to replace the bushings (2 reqd, NPD $1.99 each) in the base of the shifter, and possibly do an adjustment on the shifter to transmission rod. And it's type F. And go to a transmission shop to change the fluid and adjust the bands.
Jim
Old May 7, 2007 | 02:02 PM
dr1965's Avatar
dr1965
handle doesn't seem to whobble, just not adjusted right. Will try to adjust it tonight.
Old May 7, 2007 | 02:34 PM
Soaring's Avatar
Soaring
I ♥ Acer
You might want to check your bands and see if they need tightening. Here is how you do it.
INTERMEDIATE BAND
1: remove and discard locknut and install a new one (more than just a good idea here folks)
2: torque adjusting screw to 10ftlbs. (thats the one inside the nut, not the nut itself)
3: Back off adjusting screw exactly
a. 1 1/2 turns on 1964 C4
b. 1 3/4 turns on 1965-1981 C4
4: Hold adjusting screw from turning and tighten locknut
LOW REVERSE BAND
1: loosen lock nut several turns
3: Back off adjusting screw 3 full turns
4: hold adjusting screw from turning and tighten lock nut
Old May 7, 2007 | 02:36 PM
dr1965's Avatar
dr1965
good info, thank you.
Old May 7, 2007 | 03:50 PM
PReal's Avatar
PReal
Are these bands easily visible with the pan off?
What do they look like?
This is my first tranny work beyond a filter and fluid change.
Old May 7, 2007 | 07:08 PM
PReal's Avatar
PReal
Any more guidance?
